Clutch Assembly Arm Removal 1977 with 915
I need suggestions for removing the clutch assembly arm referenced to in Wayne's 101 Projects, page 28, diagram 4, red arrow, from the shaft. I can get a little movement from the arm on the shaft, maybe 1/8th on an inch but nothing more. I have the gearbox out of the car and disconnected from the engine in preparation for rebuild. Should I just leave it alone and let the mechanic do it? What works for you guys?
Thanks,
Clinton
"The greatness of a nation and its moral progress, can be judged by the way its animals are treated." M. Gandhi
1977 911S...sold; 03 F20C; 2009 VW Jetta Sportwagen
Old 03-22-2005, 09:58 PM
You see that pin on it?
You need to drive that pin out. Then the arm will fall right off! Without driving the pin out, you cannot take the arm off.
Old 03-22-2005, 10:24 PM
Thanks Brian, drove the pin out and the arm came right off.
Old 03-23-2005, 07:50 PM
77Porsche911's Avatar
I know this is a really old thread...but is there a specific direction this pin needs to come out? One side looks flush the other sticks out a bit on my 77 915 trans.... any help getting this off is appreciated
1977 Porsche 911S Targa
1981 BMW 520 Euro Spec
Old 04-07-2022, 02:11 PM
It is not directional. Although, if the last guy pounded it the $hit out of it and mushroomed the end then it comes out that end first. Although my guess is there is room only on one side to pound it out.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-07-2022, 02:38 PM
proporsche's Avatar
well? the best is use a puncher&hammer ..the direction is only one way ..from front ...if you have torch it helps to heat it up..even little hand held butane torch will help..after do not put it back no use for the pin..
Ivan..
1985 911 with original 502 191 miles...808 198 km
Old 04-07-2022, 02:39 PM
Thanks for the input everyone
Old 04-08-2022, 06:26 AM
