Issue with SWB spring plates / rebel racing
First SWB I’m working on so bare with me
The SWB spring plate vs rebel spring plate the inner depth is 3/4 different.
Am I missing something? I can’t even get it to go in far enough to engage teeth on torsion bar
Instagram: @TuitTech
Old 09-29-2023, 10:07 AM
They look plain wrong, way too much material. I realize that’s a huge statement of the obvious, sorry!
Nico’s Uncle John
82 911SC coupe
Old 09-29-2023, 07:41 PM
Nico’s Uncle John
Rebel racing strikes again. I think this may be the straw for me after what I went through these past few transactions with them
Old 09-30-2023, 04:46 AM
66 911 #302694
Arctic Rat's Avatar
Jim,
Do you have the torsion bars out of the vehicle? I found on my 66 SWB the torsion bars will slide all the way thru to the opposite side of the vehicle. It may be that your bar is inserted too far.
You could simply measure the insert depth on the spring plate and compare to stock ones. Put the snap ring in and insert a rule from the inside to the clip stop.
Install the bar into the spring plate to correct depth, then into the torsion tube. You may find the bar engages just fine. FYI I have Elephant racing SWB adjustable plates on my 66 with their polybronze bushings.
I will say your rubber bushings look to be very thick?
Joe D
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim .....
WOW WHAT A RIDE!!!!!!! reaperwear
Old 09-30-2023, 06:39 AM
Registered Minimalist
75 911s's Avatar
You need the really early spring plate bushing.
(Credit Grady Clay)
These parts pages below are dated 6/67 and 11/67.
#24 901.333.013.02 “Radius arm rear.”
L&R same, ely 911 with removable gummi
#26 644.333.131.00 “Rubber bushing fir
radius arm hub (inner) – up to model ‘A’.”
#27 901.333.195.00 “Rubber bushing fir
radius arm hub (outer) – up to model ‘A’.”
#53 901.333.003.00 “Rear axle radius rod
with rubber bearing. Type 911 from chassis
number 307325 on.”
From this thread:
https://forums.pelicanparts.com/porsche-911-technical-forum/302215-swb-spring-plate-bushings.html
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-30-2023, 07:01 AM
