Help finding a part!
I've worn out google searching for this part. It's a headlight connector assembly from my 79 SC. Any help in located a replacement, is much appreciated. http://forums.pelicanparts.com/uploa...1650289473.JPG
With the correct tool, the wires separate from the connectors.
The PO of my 78 hacked this up badly probably trying to get it through the holes in the bucket. I ended up just cutting the rest of the wires and using single spade connectors. |
Lights
Try searching “Porsche H4 headlight connector”. Google should turn up what you need. Sierra Madre has them and Pelican has an H5 to H4 adapter you could cut and make work.
Ok
The wiring in the buckets can be a bit confusing if you do not pay attention, so take pictures and/or label each wire if you decide to cut away the connectors. |
| All times are GMT -8. The time now is 05:35 PM. |
