7783911's Avatar
Rubber Boots for Fuel Pump
I went through the 77 PET and could not find the part numbers for the rubber boots to cover electrical connections
anyone know the numbers and or a source?
thanks
bob
Old 04-18-2022, 04:18 AM
Administrator
Matt at Pelican Parts's Avatar
It sounds like you're trying to source the rubber caps for the ring terminals, correct? Searching the forums, it looks like the original part number may be NLA.
The closest thing i was able to find are these rubber boots for the ring terminals on the oil pressure sender. Visually, they look like they may work for the purpose you're looking for. Here's a picture of them on the oil sender:
Old 04-18-2022, 09:03 AM
cycling has-been
bkreigsr's Avatar
https://www.aircraftspruce.com/catalog/elpages/termnips.php
Old 04-18-2022, 12:03 PM
A terminal nipple sounds like something I really want to avoid.
Old 04-18-2022, 01:00 PM
Diss Member
Quicksilver's Avatar
Issues, issues, issues...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 04-19-2022, 05:38 AM
any chance this is the part you're looking for? https://www.kroonwireharnesses.com/index.php?route=product/product&product_id=817 hope that helps!
Old 04-19-2022, 01:08 PM
7783911's Avatar
Looks like the PP or Spruce options are most logical replacements
thanks all
Old 04-24-2022, 04:07 AM
Part #: 999-659-011-50 is probably what you are looking for.
Very similar available on amazon: https://www.amazon.com/gp/product/B012T3YU2Y
Old 04-24-2022, 01:20 PM
