Oil filter console
Does anyone have a pictures on crankcase filter housing?
Iam interested how it looks and if adaptable to use on a street stock 3.0 1980 SC engine.
Old 10-20-2023, 09:24 AM
It's a 914 ...
stownsen914's Avatar
There's a thread that shows a few pics (though on an engine).
Help to ID this OEM Engine Cooler Blockoff
You can also google the part number 930.107.205.1R or 930.107.057.01
Old 10-20-2023, 10:11 AM
Bill Verburg's Avatar
There are 2 versions of that
N/A 993 or turbo 964/993
The turbo version is angled out a bit more, the n/a version hangs straight down
Of course you lose the engine mounted fan and oil cooler when you install these
We recently installed one on a n/a 964 case
here's the link
Bill Verburg
Old 10-20-2023, 11:06 AM
filter console
Old 10-20-2023, 11:58 AM
The 993 console requires some creativity in air direction and blocking. Because this engine is convertible from my regular installation in my 73 with heat etc to my outlaw with headers and no heat. The 993 console needs a simple ALU panel to close off the cylinder and head at #6 and blocking oil cooler duct and associated sheet metal around that corner of the engine. And a thermostat plug. With the heater air nozzles gone, I’m not worried about some air leaking from gaps.
Old 10-21-2023, 09:04 AM
