Double-check my ignition curve? (CDI+)
![]() 1981 3.0 SC w/ PMO carb conversion
Does this look right? I'm trying to follow the curve recommended in the paperwork that came with the carb kit, which is listed below:
But I'm not sure if I have to disable my mechanical advance, or if these numbers take that into account. |
(man/dude)
OK - first off a little tough love here. It maybe sounds overly harsh. Maybe it's warranted, maybe it's not, but it's for your own good. A single miss-step here can permanently harm your motor and I don't want to see that happen.
By the questions you are asking it seems possible that you don't fully understand what you are doing here. Make sure you have the knowledge and tools you need or you can severely damage your engine. That includes knowing how to operate a dial type timing light if you have one and how to read the marks on the crank pulley. And which marks to use depending on which type of timing light you have and how it's set. The installation manual for the CDI+ is available on the website. It's excellent and contains everything you need to know. By the looks of your programmed curve it looks like you need to go back and do a little more homework. You are going to need to choose between controlling advance with the distributor or the CDI+, or combining the two curves in which case the values are added together (this is referred to as "overlay" in the manual. If you install the CDI+ as you have it programmed without locking out the centrifugal advance you'll get 70 degrees of advance and BOOM!!!! To take full advantage of the programmability of the CDI+ you need to lock out the distributor. centrifugal advance. There are many detailed posts about this in my build thread. Here is one that shows the timing curve I'm running at present: Quote:
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 04-30-2022 at 05:31 AM.. |
Tee Jay,
Listen to Jonny, He has the CDI + and is very familiar with it. You are going to need to choose between controlling advance with the distributor or the CDI+, or combining the two curves in which case the values are added together (this is referred to as "overlay" in the manual. If you install the CDI+ as you have it programmed without locking out the centrifugal advance you'll get 70 degrees of advance and BOOM!!!! To take full advantage of the programmability of the CDI+ you need to lock out the distributor. centrifugal advance. There are many detailed posts about this in my build thread. Here is one that shows the timing curve I'm running at present: This info from Jonny, is of the utmost importance !!!!!!! Ian I run 30 degrees total 3.0 cis @ crank, 900 rpm 8* , 1200 rpm 12*, 1800 rpm 18*, 2200 rpm 22*, 2900 rpm 30*. all in
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
I got a single sheet of paper with my CDI+ that I thought was the "instruction manual". I'mma head off to their web site now and see if I can't find something more. Thanks for letting me know! |
The engine will start to misfire at about 2000-2500 RPM, if the centrifugal advance is not disabled.
Dave |
(man/dude)
If you look on page 51 and 52 of my build thread you'll see a bunch of stuff I did to my distributor - locking out the centrifugal advance and removing the weights, locking out and removing the vacuum advance, changing the trigger angle, and altering the rotor phasing. None of that is really necessary but in my case one thing led to another - removing the vac advance changed things enough that I felt I should check and correct the phasing, etc. Don't get too confused by all that. That's just me sharpening things to the finest possible point I can.... but you might find it interesting. One other useful bit of info is the rotor from a 3.2 Carrera fits the SC distributor, and doesn't have the goofy spring loaded rev limiter so you'll be free to set up yours in the software instead. It also has a slightly wider tip so the rotor phasing matters a bit less.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Read the manual. Re-read a couple of sections to make sure that I understood it. Looked at the sheet I was given with the carb setup. Re-read that too.
As I understand it... Measured at the crank wheel, timing should be 7* BTDC @ 1000 RPM. This is handled entirely by the mechanical advance on the distributor. With the OEM CDI installed, you rotate your dizzy until you get this configuration. That literally bottoms out my distributor's adjustment. I cannot rotate it any further. But hey, that's exactly where I need it, right? So onwards. Now, I install the CDI+. Timing is locked. Flat profile is selected. Car shows... 7* BTDC @ 1000RPM. Perfect. Now, I need to adjust the timing curve because there's a heck of a difference between the 10.5* of timing the dizzy will give me at 3000RPM and the 35* I need at the same RPM. So, I switch from the Flat profile to the Overlay profile. I change NOTHING else. It's set to 0* at 1000RPM. The idle drops dramatically. I hit the crank wheel with my timing light, and see that I'm now at about 21* ATDC. (Reiterating here, that's AFTER top dead center.) In order to get the same 7* BTDC on the crank pulley that I'd expect, I need to set my curve to adjust by +28*... So, let's assume that somehow, my dizzy is off by 21*. That's an easy enough adjustment to make - assuming that it's linear. So the table would be... ![]() The graph on the CDI+ software only goes up to 40*! This does explain how I was able to drive around with the profile I had in the original post without dying. It may also explain my drivability issues. I was running at a ridiculous retardation rate. So, uhh... How do I fix this? Do I need to pull my dizzy and rotate it by a tooth? Should I just create a new profile (or change Full Control) and set it to the final values in the above table? Or am I still not fully understanding how everything works? Last edited by TeeJayHoward; 04-30-2022 at 12:05 PM.. |
you must first lock your distributor , then you can work on your curve .
It sounds like you are also 1 tooth off on the dizzy gear. This can be fixed when you remove your dizzy to lock the advance plate, this is a video link. go to 6;10 minutes and the lock procedure is shown Max advance 30 degrees total , not 35 it is important to note in the video that he has set a 5* static or starting point , so that needs to be added to the curve total of 20* to total all in curve of 25* https://www.youtube.com/watch?v=GK-gD9_gziU Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 04-30-2022 at 01:03 PM.. |
(man/dude)
I would start by programming a flat line into the CDI+ at 0 degrees so you know it's not altering the timing. You might need to play with the trigger angle so it will idle at 7 degrees without changing anything.
(man/dude)
You don't NEED to lock out the distributor but it does allow you to take full control of the timing. Also keep in mind your trigger angle needs to be greater than the max advance you'll ever want. I have mine set to 40. You could probably use 30. Check the manual for suggestions.
(man/dude)
Checking off the "show adjust room" might help visualize that, too.
Now I can just do an "Overlay" style graph with a simple "TARGET minus MECHANICAL" formula... Right?
My mistake , no need to lock the dist advance , but I do because I want full control.
Sorry for miss leading you . Ian
(man/dude)
It will be necessary to change the trigger angle. Start with 20, then rotate the distributor 10 degrees (which is 20 crankshaft degrees) to compensate. Hopefully you have room for the dizzy to rotate, or you might have to take it out and move it a tooth. Be very aware of what you are doing and make some sharpie marks before you do anything so you can get back to where you were. I'm sorry I don't have more time right now!!!
(man/dude)
Oh and BTW your mechanical advance isn't working, if those are measurements you made with your timing light?
If it all of a sudden shakes loose and gives you a bunch more timing it will be trouble!!!!!
(man/dude)
The stock SC curve should have much more advance than that. Much more.
![]() edit: And now that I'm reading it more closely, there's a difference between a 3.0L Carerra dizzy and a 3.0L SC one, isn't there. Dad gummit. It's pretty close, though.
If you can’t get the car to start after rotating the dizzy one tooth then setting the timing then something else is going on. Check the rotor and make sure that it is seated completely in its groove and doesn’t have play. Check the green wire and make sure you have good continuity, is it wedged against something, are the wires frayed?
Still can’t get it going? Then start over, zero out the CDI curve and use the dizzy mechanical curve or lock the dizzy and use the CDI curve. Sounds like their battling each other right now so you have to lock one of them out. I think what Jonny was referring to with the curve, is that your chart shows that you have 10 degrees mechanical at 3500 rpm’s with a target of 35 degrees. He is telling you that dizzy mechanical advance is normally more like 35 degrees. So if yours is stuck at 10 degrees and it unsticks you’re up around the 70 degree range if you also add in CDI advance.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Reference below screenshot from your posted chart. This is a mess, it can’t happen, and if it is then your advance is stuck with some type of intergalactic goo. And it isn’t locked out if that is happening.
![]() Now get back out there and figure out WTF is happening, we are all rooting for your Jedi build!
Oh, and I got the car running one tooth off! I must have gone too far last time. ![]() 35* of trigger gives me enough headroom, too. edit: OK, What the hell. This is from the Porsche workshop manual: ![]() "You need to be at 30* BTDC @ 4K RPM" but vacuum and centrifugal advance combined would only be 15*. Am I supposed to be doubling the Y axis on these charts? edit2: Apparently that's exactly what I'm supposed to do. Quote:
Gah! edit3: If I add the 5* the manual wants, and double BOTH axis, I get something that kinda looks right?
