Not Weber KN rain hats?
So I picked these up to use on some ITBs, but I have since traded that setup. I was going to use these on a recent acquisition of Zeniths, but realize the bottom plate is not correct. I was told they are for webers, but clearly they are not. What other triple carb uses this bolt pattern? Just curious before I drill my own.
http://forums.pelicanparts.com/uploa...1651282529.jpg |
Pmo
Thanks Al! In that case maybe I shouldn't drill new holes. Anybody want to swap?
Cut away the central portion as needed
What I mean by that is the original designs are tough to work with. Larger openings make it easier to get to the emulsion tubes on zenith’s. |
