Not Weber KN rain hats?
So I picked these up to use on some ITBs, but I have since traded that setup. I was going to use these on a recent acquisition of Zeniths, but realize the bottom plate is not correct. I was told they are for webers, but clearly they are not. What other triple carb uses this bolt pattern? Just curious before I drill my own.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Pmo
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks Al! In that case maybe I shouldn't drill new holes. Anybody want to swap?
Cut away the central portion as needed
What I mean by that is the original designs are tough to work with. Larger openings make it easier to get to the emulsion tubes on zenith’s. Last edited by VFR750; 04-30-2022 at 11:16 AM.. |
