Carb / dyno tuning in SoCal?
Well, my car is together and put about 20 miles on the engine. Seems to be running good, but a little stumble / roughness from 2-3.5k. After that, it screams. Can't believe the noise this thing makes now! Would like to get it on a dyno and get it dialed with timing, jetting and the like. Anyone in the LA area know who to see? I'm actually in Ojai, but will travel as needed.
Engine is a 3.0 with twin plugged, large port head (flow benched), DC60 cams, 10.6:1 comp, PMO 46's (William Knight), arp etc. etc. Gearbox is SCRS geared, so 5th is 1:1.
Under the radar
Here is all you need IMO.
![]() PCA has used JBA Speed Shop in San Diego. Not sure if they still have any Weber experts.
Club racing guys need a HP chart for club competition director to have on record, they go here a lot.
Aase Motors is nearby too for tuning. Superior Automotive Engineering - Dyno Tuning Los Angeles - High Performance Automotive Services
1980 911 - Metzger 3.6L 2016 Cayman S |
Aase handled my 46 PMO's. The are some of the nicest guys in the business and do excellent work to boot.
Same here. When I had pmo carbs and had a bunch of issues I took them to Jeff at AASE. They tuned the carbs on the dyno and identified and repaired a few other issues.
Thanks folks. I think i'm going to start with the AFR and get as dialed as I can, then take it to see what she makes and maybe swap exhaust or other mods there.
I will second the wide band to check AFR. You can then check AFR by driving around. You can have a fairly wide mixture range that makes the same power. Once mixture is dialed in you can play with timing on the dyno to find best safe HP.
john |
What is a good lambda sensor gauge setup available? One should have a sensor on each bank ,no?
I will not mount it permanently but just for tuning. |
I run an innovate AFR gauge in my MGB with a Chevy 60 Degree V6 swap with a Holley 4barrel. They have several different options depending on how you want to log the information.
Ideally 1 per bank is good, or for even better info, individual cylinder EGTs and 2 or mor lambda sensors is the best info. Individual EGT will let you know when you have a clogged jet which is somewhat of a common experience with carbs in my experience. If you have a lambda sensor per bank, that will tell you when one bank is running rich of lean but individual cylinder EGT will tell you which cylinder has the fuel or spark issue. |
(man/dude)
I would second the sentiment that you're better to tune it to AFR and maybe visit the dyno for fun at a later date once you think you have it sorted.
I like to keep it simple - single AFR and keep a close eye on the plugs to make sure everything is looking even. Mind you I have MFI and once the pump is setup it's pretty bulletproof from a fuel delivery/distribution standpoint. Innovate sometimes gets a bad rap for doing things like eating sensors but mine has been through two driving seasons of hell with me getting the tuning and space cam mods done on the 3.2SS MFI. I have one of their MTX-L plus gauge/comtrollers, an SSI-4 logger so I can log RPM and throttle position, and a pocketlogger which puts the data on a microSD card. The logging is really fun. One useful thing it allowed me to do is compare ****ing times between Swepco 201 (1.000+sec.) and Motul Motylgear 75W90 Technosynthese (0.600 sec.) All the logging stuff is in my build thread. Here's one example: Quote:
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Under the radar
If you post the details of your carb setup, I'm sure the experts will chime in with opinions on your jetting.
Performance Oriented Has a ton of info on setting up webers on 911s. Hosted by Paul, aka 1QuickS here.
Eng-o-neer
I don’t know about THAT cool…… but they are much cheaper. Haven’t dynoed it but feels like 180whp but she is all done by 6000 RPM and T5 gearboxes aren’t all that. The whole performance engine build was less than the P&C for my 911 though so there’s a reason one is done and the other isn’t.
I built a MGB with a 4.3 Chevy and 4 barrel holley tied to a turbo hydomatic may years ago. It was quite fast.
john |
