Harpo's Avatar
front/center mounted oil cooler
Good afternoon everyone,
What is everyone using for a front mounted oil cooler?
Old 04-18-2021, 12:14 PM
Bill Verburg's Avatar
5 1/2 X 2 1/4 X 20 B&B w/a 993 3.6+
Bill Verburg
Old 04-18-2021, 12:45 PM
Harpo's Avatar
Thanks Bill but the B&B is not in the budget.
Does anyone recognize this front oil cooler from omgjon's build?
Old 04-19-2021, 08:58 AM
Harpo's Avatar
Old 04-19-2021, 09:14 AM
We offer the two center mounted oil coolers from CSF Performance Coolers, A single pass cooler and a dual pass model.
Old 04-19-2021, 09:28 AM
FWIW, I have the CSF single-pass cooler on my '87 and I love it. Very efficient, and packages well. Shoot me a PM if you want see up close (I am near you in BH).
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 04-19-2021, 09:52 AM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
I have a used front mounted oil cooler that measures 5-1/2" X 2-1/4" X 24" made in Japan by Calsonic for the Nissan Skyline, a Mazda RX7 among other models. Comes with two braided stainless steel covered oil lines. All for under $400.00
If interested PM me with your email address for details.
TIA
Henry
Old 04-19-2021, 10:10 AM
Harpo's Avatar
Thanks that looks like a serious contender.
Thanks for the offer Lyle. What are you using for a front bumper? Why a single pass?
Old 04-19-2021, 10:12 AM
RETIRED
Joe Bob's Avatar
BAT Inc cooler. Under $400. I will PM you my name to use.
2012 ML350 3.0 Turbo Diesel
Old 04-19-2021, 12:10 PM
RETIRED
Joe Bob's Avatar
Make sure you use rubber isolation mounts. Coolers don't like vibration.
Old 04-19-2021, 12:25 PM
3rd_gear_Ted's Avatar
A 964 nose allows more air flow space behind the oil cooler than on an IROC nose.
Minimum AN fitting size the on cooler inlet/outlet lines is -20
Don't fall for the AN -12 hose kits being sold.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 04-19-2021, 01:39 PM
Racer
winders's Avatar
AN -16 is just fine......
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 04-19-2021, 02:33 PM
I have a Ruf-style bumper/valance. This cooler fits there well. I plumbed it in-line with my front fender-well cooler w/fan (I have an '87), so this provides extra capacity for an already pretty good system. When I added a turbo, I noted higher temps and wanted them to return to "stock" levels. With this additional cooler, I achieved that in spades.
'07 Boxter
Old 04-19-2021, 03:23 PM
Great vertical orientation position chosen for your Oil Cooler, like the flow thru aspect for the airflow.
2016 Cayman S
Old 04-19-2021, 04:16 PM
Lots of people use the Mazda RX7 oil cooler and weld on AN fittings. -12, -16, -20. Omit or run the internal thermostat. Do a few searches here. I've run one on my 930 for oh, almost 30 years now.
Old 04-19-2021, 06:18 PM
Harpo's Avatar
My new oil cooler. Made an adapter because I didn't think that the threaded engagement in the aluminum cooler was adequate. They did install helicoil so most good enough
Old 04-28-2021, 02:55 PM
Harpo's Avatar
In this position it will sit directly under the factory SC bumper. Obviously the valance will need to be extensively modified
Old 04-28-2021, 02:59 PM
Harpo's Avatar
For some reason my fusion 360 file is not being shown completely. Regardless this flat piece of steel will be folded in to a box to frame my oil cooler. Or at least that is the plan in my head. We shall see if my plan works out
Old 04-28-2021, 03:12 PM
Harpo's Avatar
Here are the water jet cut parts
Old 04-30-2021, 12:10 PM
Which make/model of oil cooler did you decide on? Thank you
If you give your word: keep it.
Old 04-30-2021, 03:38 PM
