-   -   Electronics Help (CDI) 3 Pin (http://forums.pelicanparts.com/porsche-911-technical-forum/1118101-electronics-help-cdi-3-pin.html)
millerjon101 05-02-2022 02:18 PM
Hello,
I built a simple DIY CDI a while back and after doing some research I saw even the early BOSCH 3 pin CDI is much much more complex. I considered making a BOSCH 3 pin as it's proven and the added complication has to have significant advantages. After studying it a bit as far as I can tell the trigger circuit would not have enough current flow to switch on an SCR capable of handling the current of a strong CDI. I am specifically interested in the trigger circuit of the bosch CDI as I am happy with my power supply. Any help or insight is greatly appreciated.
Thanks,
Jon
http://forums.pelicanparts.com/uploa...1651526279.jpg
Trackrash 05-02-2022 07:46 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/226517-history-bosch-cdi-toubleshooting-info-parts-list-changes-schematics.html
mysocal911 05-02-2022 08:42 PM
Originally Posted by millerjon101 (Post 11681683)
Hello,
Thanks,
Jon
Actually, that's not the case, i.e. the trigger circuit of the Bosch CDI is properly designed to "fire" the SCR (Thyristor).
Read here; https://www.circuitstoday.com/thyristor-vs-transistor
