Certified Pre-Owned
Howdy-
Fuel pump sounds like a faint weed whipper engine... Obviously, I'm on borrowed time but how much time? -BG
'84 Carrera Coupe |
it has one foot in the grave, and the other on a banna peel
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Are you a gambling man?
If not change the fuel pump now or at the very least join a motor club so that you can have the car towed(?) flat bed back to your garage or mechanic. |
Certified Pre-Owned
I guess that would place me at the cemetary next to the county zoo...
'84 Carrera Coupe |
One thing you might want to check before you get a new pump: any chance the current pump has made contact with another metal peice down there and is resonating against it? It's been known to happen.
If not, then go ahead and get that AAA membership.
993 |
Irrationally exuberant
I 2nd what cowtown said (check for vibrating belly pan). I would add that a dying fuel pump puts an extra load on the DME relay. You may want to replace the DME relay after you replace the pump. The DME "relay" actually has two relays inside one box; a fuel pump and a DME relay. Open the old relay and look for a darkened (from heat) area around the inner relay that feeds the fuel pump.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Certified Pre-Owned
Yup, I've already replaced the DME relay. Heck, I've almost replaced my entire car now. I did my 27th Pelican order today since I bought this thing back in August. Had a corner balance and alignment done this week too...
'84 Carrera Coupe |
Hey BG... how many miles on the pump..............Ron
-Chris |
