Is this Overkill?
My car gets hot during high RPM low speed driving.(Auto-X) I installed some fans to the oil cooler. Does anyone think these will pose a clearance problem? I have the car up on 4 jackstands so I couldn't check. But I will verify clearance issues before I spend time wiring everything.
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
the cooler would have to be farther forward than the factory position for the tire not to rub. even the factory louvered panel behind the cooler comes mighty close. no room on the front side? hopefully those fans suck instead of push. they will also get killed by rocks and mud slung off the tire.
They should be very effective at low speed cooling. Any room to put them in front of the cooler? In this position, they look vulnerable to gravel hits. Do you know if all three fans are necessary? One or two might do the job - three might be superfluous. How about three more on the other side too?
Sorry, couldn't resist.Sherwood Lee http://members.rennlist.org/911pcars |
Shawn,
You have been looking at too many computer over-clocking sites.
Neil '73 911S targa |
Senior Member
Are the fans waterproof?
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Might be able to squeeze one in front of the cooler. Limited space because of the battery box. The fans are pulling air thru the cooler. I may mount one pushing at the front on the bottom and one pulling at the top on the back side.
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman Last edited by thrown_hammer; 05-23-2003 at 10:04 AM.. |
1.367m later
You might want to consider putting those fans in front of the cooler. I've seen fans melt from pulling the heated air from the cooler. Installing the fans in front of the cooler with the factory stone gaurd in place to protect the cooler and to stall the air long enough to transfer some heat from the cooler to the air would be more effective.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Automotive Monomaniac
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
clearly this calls for carbon fiber and titanium. Shall I call a friend at JPL? I think they have a few of these special spec fans next to the $15K toilet seats...
ON a related note, it was fun to watch last week's F1 race during the multiple restarts, with the crews running out to evidently dump dry ice into the system to keep the engines from melting down. egad! |
IMO it looks as if the presence of the 3 fans may reek havoc with the airflow thru the cooler at higher speeds.
Warren & Ron, may you rest in Peace. |
Everything said here is right. Biggest issue will be stone damage. Those plastic fan blades are brittle. One hit and the fan will disintegrate. Need to protect them with a stone guard similar to the stock Carrera setup.
Tony K '89 944T 944 SuperCup Champ 2004 & 2005 '85 Carrera - Sold [sob] TrackVision 944Cup The 999 Site |
Thats why I come here guys. So will one fan in front of the cooler be effective enough? (cause thats all i would have room for in the front)
Yes to the one fan. but do get a good fan. Buy a spal pull fan. I've had one hooked up to the IC on my saab for over a year and it works great. Super tough.
http://www.slickcar.com/spal-fan.asp?offset=40
72 911 Although it is done at the moment, it will never be finished. |
Hey are you calling my fans...umm...NON good?
Heck no! I have a fan like that one as well sucking air from below my engine compartment and pushing it through a tube, and into one side of my air filter on my saab. But it's not in an area that will be hit with rocks and such. Not as strong as a spal either.
One fan in front(two if I can squeeze them in)of the cooler it is!
Thanks guys.
Banned
will you be wiring the fans through the fuse panel or just off the battery with an inline fuse and switch?
I was thinking off the battery with an inline fuse and a small toggle switch. The car runs cool at speed. So I would just switch it on at auto-X's and what not.
On mine, I went down to Kragen and bought a fog light relay kit (15amp fuse). Wired in a switch in the dash that is on or off.
I have exactly the same thing sitting on my shelf in the garage. Hope to have everything wrapped up by the end of the long weekend.
