964 oil pressure in 71 chassis
Yes, it is a 911 frankenstein with a 964 3.6L engine in a 71 chassis.
Here is the gauge, key on, engine off. So there is continuity and gauge is working.
When the engine is running, there is oil pressure, but the needle is pegged at the top all the time, even at idle. So my guess is the oil pressure gauge is not correct for the 964 oil pressure sender.
So ...
1) Do I change the pressure sender to that of a 71 2L engine?
2) or Do I change the pressure gauge to that of a 964 chassis?
I'm guessing choice 2 ... is better.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-13-2022, 11:03 AM
msmall215's Avatar
Patrick Motorsports makes 2 versions of an oil pressure sender for 3.6 conversions in early cars, a single and dual pole:
https://patrickmotorsports.com/products/eng36oilps2pms?_pos=5&_sid=0a9c531a3&_ss=r
https://patrickmotorsports.com/products/eng36oilps1pms?_pos=6&_sid=0a9c531a3&_ss=r
Mike
'85 3.2C
IG: @msmall90 | @zuffenphilly | @ruchlosrallye
Old 05-13-2022, 12:59 PM
This is a good solution. The other option is to replace the pressure side of your gauge with a 0-5BAR from a 3.0 gauge.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-13-2022, 02:40 PM
Have you got any idea where I could source one of these, other than ebay?
Old 05-13-2022, 04:27 PM
Sorry, I don't. Try a WTB on here. It's probably going to be hard to find just the pressure gauge so you'd likely have to buy a complete temp/press gauge. Might be cheaper to buy the sensor from Patrick.
Old 05-13-2022, 06:20 PM
Use a 76/77 pressure sender with the 0-10 bar
Bruce
Old 05-13-2022, 06:34 PM
