3 PIECE fUCHS WHEELS
Does anyone know of a service that can build wheels from Fuchs centers. Bob Woodman tire used to do that but don't think he does any longer. Thanks, Bob
I'd buy a set of Fikse 17s w/ custom widths and ETs, much better tires choices in 17s or 15s compered to 16s
Running a 78 911, and I guess you could put 17s on it. Don't think that size is allowed in the vintage events in which I run though. 15s won't clear my brakes. Think I am stuck with 16s.
stock 9ET15 will be fine for the back of an SC. the 8s are the issue as the stock Fuchs only come ET23.3 or ET10.6 and for an 8 front you want ET27 I always wondered if maybe 3.7mm could be machined off the back of the ET23.3 , You might not even have to go that far, I use 8ET25 w/ some surgery on the fender lips.
The guys that make the duck tails out of central FL make them.
