Question Jet Setting Sanity Check
I'm slowly learning about jets as I rebuild these Zenith 40 TIN carbs. Can I get a sanity check that I'm approaching this correct?
Main Jet: 115
My 120 gauge went into two of them with not much effort. I assume these are out of spec and need to be replace. Perhaps just as well. One doesn't even appear to have a hole, which I don't understand.
Air correction jet: 195
The carb pin gauges I bought only go to 1.5mm. I used the solid end of drill bit on the 195 and found 1/16th (1.6 mm) was a go and 5/64th (1.97mm) was a no go. Is this close enough to judge 195 jets are probably correct?
Idle fuel jet: 47.5
One of these seems so plugged or corroded I can't get a gauge in it. Can you replace a single jet, or are they meant to be done in sets?
Thanks for helping with my newbie carb questions.
Old 10-01-2022, 12:19 PM
one jet at a time is fine , just as long as all jets are the same measured size for both carbs
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 10-01-2022, 01:37 PM
