Stupid P&C question
When increasing the bore on a 3.0L, do you need to bore out with the case or do the new cylinders have a thinner wall?
The most common method is to bore out the cylinders while leaving the case alone. This leaves them with slightly thinner walls, but if kept within reason, has not really been cause for concern.
100mm and larger case work |
That explains the love for the 3.2 I'm seeing around here!
Thanks guys! |
Correct, the '84-89 3.2 is 95 x 74.4 for 3164cc, the previous gen 3.0 were 95x70.4 for 2994cc
put 98s w/ a 70.4 for 3186cc or 98 w/ 74.4 for 3367cc the ones w/ potential issues are the 100mm bore motors which have reduced the meat between the cylinders reducing stability stud spacing for 2.0 - 2.7 is 83mm stud spacing for 3.0 - 3.3 is 86mm stud spacing for 3.8 - 3.8 is 90mm all have the same cylinder ctr @118mm w/ 59mm stagger |
Oops, I meant the 3.2SS. (At least, I think that's what ya'll call the 98mm cans on the 3.0L crank!)
You need Carrera cylinders to open to 98mm because of the head sealing
SC cylinders can do 97mm for 3.1liter and maintain the head gasket. Bruce |
| All times are GMT -8. The time now is 08:40 PM. |
