Stupid P&C question
When increasing the bore on a 3.0L, do you need to bore out with the case or do the new cylinders have a thinner wall?
Old 05-21-2022, 09:34 AM
The most common method is to bore out the cylinders while leaving the case alone. This leaves them with slightly thinner walls, but if kept within reason, has not really been cause for concern.
Jonathan
'79 Copper 911 SC
'88 White 911 Carrera- 98mm p/c with JE 8:1, Turbkraft EFI-T cam, Carrillo rods, Injector Dynamics 1050x, twin COP, AEM Infinity, twin Garrett GT2860rs's
Old 05-21-2022, 09:54 AM
Bill Verburg's Avatar
up 98mm bore no case work
100mm and larger case work
Bill Verburg
Old 05-21-2022, 10:15 AM
That explains the love for the 3.2 I'm seeing around here!
Thanks guys!
Old 05-21-2022, 11:24 AM
Thanks guys!
FWIW, the 3.2l Carrera engine has the same bore as a 3.0sc -- its larger displacement comes from a crank with a longer stroke
Old 05-21-2022, 12:08 PM
Correct, the '84-89 3.2 is 95 x 74.4 for 3164cc, the previous gen 3.0 were 95x70.4 for 2994cc
put 98s w/ a 70.4 for 3186cc
or 98 w/ 74.4 for 3367cc
the ones w/ potential issues are the 100mm bore motors which have reduced the meat between the cylinders reducing stability
stud spacing for 2.0 - 2.7 is 83mm
stud spacing for 3.0 - 3.3 is 86mm
stud spacing for 3.8 - 3.8 is 90mm
all have the same cylinder ctr @118mm w/ 59mm stagger
Bill Verburg
Old 05-21-2022, 01:42 PM
Oops, I meant the 3.2SS. (At least, I think that's what ya'll call the 98mm cans on the 3.0L crank!)
Old 05-21-2022, 09:16 PM
You need Carrera cylinders to open to 98mm because of the head sealing
SC cylinders can do 97mm for 3.1liter and maintain the head gasket.
Bruce
Old 05-22-2022, 04:15 PM
