spoke's Avatar
Which CIS Test Kit for '86 930?
I'm looking to test the CIS pressures on my '86 930. I purchased one kit that didn't have the fittings I need:
https://www.amazon.com/gp/product/B008FJXA3M/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Anyone have a kit that actually has the fittings for my 930?
I've seen others recommend the S&G 33800 kit.
I've read that Pelican has a kit but I can't even find that.
Thanks in advance.
Find Spoke's LED Products:
www.spokeworksled.com
Old 05-23-2022, 05:30 AM
spoke's Avatar
I see this kit as well which has a lot more fittings than the CTA 3420 kit.
BETOOLL Pro Fuel Injection Pressure Tester Kit Gauge 0-140 PSI with 9.49,7.89,6.30 Fuel Line Fittings
https://www.amazon.com/BETOOLL-Injection-Pressure-Tester-Fittings/dp/B082Y5FMQN/ref=sr_1_44?crid=16MIOETRUKDO9&keywords=CIS+Tester+33800&qid=1653308092&sprefix=cis+tester+33800%2Caps%2C52&sr=8-44
Old 05-23-2022, 05:33 AM
Full Send Society
You can also buy individual cohline fittings from bel metric…. That’s what I had to do to piece together a kit that worked for all parts of my 77 CIS
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 05-23-2022, 05:52 AM
Local PP member........
Spoke,
You will need an adaptor (8-mm x 1.0/ 12-mm x 1.5) for your 930 fuel distributor. These adaptor/s are available with the S&G tool kit. I have a few of them if you need one.
Below are some of the adaptors I have accumulated from having 5 sets of S&G kits.
Try to use a fuel gauge with 12-mm x 1.5 fittings for your CIS and they are standard fittings for S&G kit. In case you can not locate a set of gauges, you are more than welcome to borrow one of S&G 33800 kit.
Tony
Old 05-23-2022, 06:47 AM
spoke's Avatar
Tony, bought the S&G 33800 kit and it has fittings for my 930. I disconnected the fuel line at the WUR and inserted the gauge there. Thanks for the recommendation.
Old 05-29-2022, 02:41 PM
