CDI+ advance/programming issue
I'm running my CDI+ in full control mode. The dizzy is locked. Here's where the dizzy rotation is...
http://forums.pelicanparts.com/uploa...1653346146.jpg Here's my CDI+ curve: http://forums.pelicanparts.com/uploa...1653346146.jpg The problem is that according to my tuning software, my advance is maxing out at 20 degrees. The minimum appears to be 10.5 degrees, which is occurring at about 1K, which corresponds nicely with the curve. It's my understanding that this is showing that the dizzy rotation is providing 10.5 degrees of advance, correct? And as such my advance should be maxing out at above 30, correct? (a bit too much, I know). As you can see my trigger advance is set to 40, which should give lots of room. Is the problem that my dizzy needs to be rotated more? If so how much would one try for? And I take it if I do this I need to reset the CDI+ curve, correct? Thanks for your input!!! |
It’s been pointed out to me in my other thread that with my setup the tuning software I’m using isn’t seeing the timing accurately. So, it seems best to ignore that data. I’ll add that the cdi+ software does show the timing advancing along the curve all the way up to max, so that makes sense.
Gotta love this board!! |
Reading through a few other threads on this topic I have a few questions, hopefully someone with experience/knowledge can chime in.
First, I rotated to the timing mark on the flywheel with a timing light- 5 deg. I locked the dizzy. Next I set the CDI+ in full control mode. The curve above was written to the unit. I'm confused about the trigger point, what should my Trigger point be set to? I have it set in the profile to 40 deg to allow for enough adjust room. But, given that my dizzy is rotated to 5 deg, am I interpreting correctly that in order to allow for enough adjust room the trigger point should be set to 10 deg? And, If I do that most of the curve will be in the red zone, so then I would have to rotate the dizzy to 20 deg AND reset the trigger point to to allow for 40 deg of advance, correct? If I rotate the dizzy with the engine running and this profile applied, I should see no difference in rpm, correct (?), since the CDI+ will be retarding the spark signal? Or does rotating the dizzy to 20 deg then change the baseline advance, so the cdi+ is then adding 24 degrees of advance at the top of the curve for a dangerous 44 degrees? This may be a stupid question but how do I find the 20 deg mark since there's no other notch on the flywheel? Is it literally 3x the distance along the flywheel from the 5 deg mark? |
Two things - have you read the FULL manual available on the Classic Retrofit website? If not you owe it to yourself to read the whole thing.
Also, check off "adjust room" on the software. It will show you the max advance you can run for a given trigger point. If you take the time to read and fully digest and understand the problem you'll be fine. PS you have, and are using, a dial type timing light to verify timing, right? Otherwise you are shooting in the dark. |
I'm a little confused about the full control setup process. I watched the video several times, can someone please verify this is the process?
Set the curve with timing set at 5 degrees. Adjust the tigger point to allow for more working room. Send the file to the unit. Adjust the dizzy with timing light to match what's on the software curve. Correct? |
CDI+ Manual
Page 25: "Trig Advance The amount of advance in engine degrees that the distributor should be set to. See Adjust Room in the following section for a detailed explanation of this setting." Page 28: "Adjust Room The CDI+ uses a microprocessor to calculate the exact time to fire the spark depending on the engine RPM and the advance required. In order to do this it must be able have the distributor trigger signal before the spark is actually required. [The way the CDI+ achieves advance is to receive the trigger signal from the distributor 'early' and then delay the firing of the coil according to the advance curve. To get the early signal we must rotate the distributor further in advance. We call the value for the distributor rotation 'TRIG ADVANCE'. The angle of advance at the distributor should be half that of the value of TRIG ADVANCE. Now, let's say the TRIG ADVANCE is set at 15 degrees - it should be clear that any advance in excess of 15 degrees would not be possible as the spark would have to happen before the trigger. In addition, there are other delays that compound the time required by the unit, read on... ] The total amount of time required we call the 'adjust room'. The adjust room required is a function of TRIG ADVANCE, the amount of advance required and also the input delay through the points and electronics. All of these combine to form an area that is potentially unreachable on the graph. This can be displayed on the graph using the 'show adjust room' checkbox. If the area is breached the 'ADJUST' flag will also be illuminated. If this happens, then the distributor will physically need turning further in the advance direction and the TRIG ADVANCE setting changed to match. In practice, it is not really an issue as most cars do not require more than about 30 degrees. If more than this was required, it just needs more physical advance on the distributor. In extreme cases this may require turning the distributor one tooth on the drive gear." Page 29: "Full Control mode. In Full Control mode, the distributor weights and springs are physically locked..." continued on Page 30: "The total ignition timing is controlled completely by the unit. Remember though, that the static timing of the distributor is still offsetting these values. For example, on an SC, the static timing at idle is set to 5 degrees BTDC. Using the graph above, the advance shown is 0 on the graph at 1000 RPM. This means that the total advance at 1000 RPM is 0 + 5 degrees. At 6000 RPM, the graph shows 24 degrees but the total timing will be 29 (+ 5 for the static timing)." So even though your distributor is locked (causing no CHANGE in timing relative to RPM), the actual timing is whatever position the distributor is set to (aka static timing) plus what the CDI+ is adding. The distributor needs to be set to a position where the CDI+ is getting the signal from the distributor BEFORE it is needed. Which is why the static timing should be set to half the TRIG ADVANCE value. This adds up to the area displayed with the "show adjust room" checkbox. Interpret that as "adjustment area we can't reach based on the static timing/TRIG ADVANCE as currently set" DISCLAIMER: I'm still making notes before having CDI+ control my timing, so take the above with a grain of salt. Ultimately though, I think you should be able to setup your timing light and confirm the true overall timing, regardless of whether it's set by the distributor, CDI+ or both. |
This thread underscores the fact that once you put the CDI+ in full control you have all the power in the world to make adjustments - for better or worse.
If you don't become enough of an expert on your own so that you can sufficiently understand, test, verify with a timing light, adjust, verify again, etc, add infinitum, you are running the risk of asking the wrong question, misinterpreting the correct answer given you by a well meaning forum member, and getting the wrong result. That said, groovydude, I think you're on the right track. Try it, verify it, and don't drive the car at full load/RPM until you're sure you're only getting your intended max timing. Some of the questions you asked earlier in this thread lead me to think you either don't have a dial type timing light, or aren't fully understanding the one you have. With a dial type timing light you are best to ignore every other mark on the crank pulley and refer only to TDC and use the dial. |
PS - With the CDI+ in full control mode you have three ways to adjust the timing:
1. the position of the distributor 2. the trigger point in the CDI+ software 3. the curve of the software Change one, and you'll change the timing. Change two in equal but opposite directions, nothing changes. Change all three and who knows what could happen? (You get the point) |
how did you "lock the distributor". Did ou remove it and then rotate the advance mechanism and fasten it to that position?
https://cdn.shopify.com/s/files/1/00...9700_1200x.jpg |
I locked the distributor with the brass thingy that Classic Retrofit sold me (see pic above).
This is a response from Jonny H from Classic Retrofit: If you are wanting a max advance of 23 deg on the graph (before adding the 5 static to make 28), you'll need to set TRIGGER to at least 35 (so it is not in the red) and rotate the distributor 35/2 = 17.5 degrees. Whatever changes you make, always verify with a timing light. I've got a dialed timing light on order, I'll post after it's all set. |
Surely you're aware that simple timing changes can be made by just re-positioning the distributor. Have you done before and after dyno tests? |
https://www.systemsc.com/products.htm If you really are that desperate for work, why don't you advertise in Panorama or something instead of sneaking around here wasting everyone's time by asking questions you should already know the answer to? |
Consider reading post #11 here; http://forums.pelicanparts.com/porsche-911-technical-forum/1119451-best-ignition-coil-use-cdi-classic-retrofit.html |
https://www.pelicanparts.com/catalog/SuperCat/5871/POR_5871_ELIGNT_pg2_bosch-cd-ignition-units.htm |
And if you're seriously going to ask for dollar-for-dollar justification of spending on cars, a Porsche forum is the wrong forum IMO. |
http://forums.pelicanparts.com/porsche-911-technical-forum/894670-classic-retrofit-cdi-dyno-results-11.html#post10483546 |
and a reduction in reliability because of the added number of components. You're aware that a system's reliability decreases with the increasing number of components. Quote:
| All times are GMT -8. The time now is 12:50 PM. |
