(man/dude)
Jonny042's Avatar
Originally Posted by Mothy View Post
I have to agree with Jeff above.
Plus best value for me in that it replaced an old and risky device with something modern, adjustable, that increased performance in the area where I spend most of my time in the lower rev range.
The ability to avoid a costly 10k rev tacho conversion and have an adjustable rev limiter is a big bonus.
Cost difference with other alternatives is not big.
To me it represented good value. Thanks to Jonny for helping keep our older cars running well.
Tim
Along with all the above things, the ability to have adjustable control over the MFI cutoff solenoid is a huge plus for me, since I did not have the original speed sensitive relay. Again avoiding 40 year old electronics, and simplifying the car, and not adding another box from May Suddenly Die (MSD).
In fact I was one of the first to ask about this as a possibility (I think I figured that instead of controlling a shift light, it would be simple to connect it to the circuit for the cutoff solenoid). Jonny's response was to get back to me in the affirmative after looking into it, and now, after a simple software update, it is listed among the features. How is that for service and support?
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 12-06-2018, 07:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
(man/dude)
Jonny042's Avatar
Tim
You forgot the ability to lock out the distributor curve and program it with the CDI+!
Old 12-06-2018, 08:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
I’m looking to switch from CIS to carbs. I know I need the distributor recurved and the ignition upgraded (MSD seems to be common). Would I be able to solve both of these problems with a CDI+ unit?
_______________________________
1982 911 SC 240,000mi and counting
Old 12-12-2018, 05:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
Jonny H's Avatar
In a word, yes. As long as the distributor bearings are ok, save your money on a rebuild and mechanical recurve.
Also, see post 163 a few pages back for a CIS car coverted to carbs. You can expect some pretty nice results!
www.classicretrofit.com
Old 12-13-2018, 12:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
Awesome, thanks for the quick reply. I think a CDI+ will be my first step, I can use it with my current CIS setup and then with the carbs when I finally get everything else purchased and ready to install.
Old 12-13-2018, 03:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
Very impressed with performance increase CDI+
Just mounted classicretrofit CDI+on my 1980 911 sc with lamba.
Had it on Dyno in October 2018 just before I drove it in the garage for the winter and it showed 176.8 HP at 4900 rpm and 267NM at 4200 rpm which I was actually very pleased with when the factory spec says 247NM.
But just look what the numbers show now after classic retrofit ignition is mounted, I'm impressed.
191.4HP at 4500 rpm and 294NM at 4200 rpm on a complete standard engine.
The only change is the classic retrofit ignition and another air filter inlet box, nothing else.
1963 356 SC, 1980 911 SC targa
Old 06-07-2019, 07:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
Jonny H's Avatar
^ Thanks for posting. Nice result and well done for bringing this back on topic!
I must admit the first few pages of this thread wore me down so it is really nice to see people take the time to post their actual experiences.
Old 06-07-2019, 02:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
Jonny H's Avatar
Nice little 69 T 2.0. These early LWB cars ran standard inductive ignition, with only the E and S models getting CDI systems.
Big uplift in performance installing CDI+ with no other modifications. Still runs the original Marelli Distributor.
https://www.instagram.com/p/CLqthPOl5kX/
Old 02-26-2021, 10:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
I've been using a CDI+ on my 70S for the past 4 years and I highly recommend it. It is a solid high quality product. From idle to redline car runs smother, and with less vibrations compared to my rebuilt Bosch CDI.
Old 02-26-2021, 12:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
Fubawu's Avatar
Do you have any comparisons to the MSD 6AL?
www.machine-motorsports.com
1971 911T 3.2 1971 911S 2.5
1972 911S 2.8 1972 911T 2.7
1965 911 300760 1976 911S
Old 02-26-2021, 01:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
Jonny H's Avatar
Thanks for the post. Early 'S' models do seem to respond particularly well.
Lovely looking car btw.
Old 02-26-2021, 01:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
Jonny H's Avatar
Oddly, only on a Jaguar E-type 3.8 6 cylinder. Both MSD and CDI+ made around 25HP over the standard Kettering system. CDI+ showed better mid range power ( 3000 - 5000 ). MSD is not that common over here (UK). In fact, I don't know any 911 engine builders in the UK or mainland Europe who use MSD.
CDI+ is plug and play with the original coil, leads, cap, rotor and it looks right in the engine bay.
MSD wants a new coil (which is a $10 Chinese made coil) , leads and removing resistors from rotors. The primary coil voltage is ridiculously high at 530 volts which is more demanding of coils, leads and also why the rotor resistor burns out. Plus, all that bright red makes my eyes hurt.
By spec:
MSD : Voltage 530v. Spark Interval 1000us, Multispark to: 3000 RPM
CDI+: Voltage 400V. Spark Interval 400us, Dual spark to: 12000 RPM
Old 02-26-2021, 02:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
Puny Bird
Mark Henry's Avatar
Builders use them because they're cheap and plentiful this side of the pond.
Their primary coil voltage is ridiculously high because they are made to fire monster V8's with blowers. In my case, 914/6 conversion, they're a good solution when you have none of the original kit. Plus my PMS/Jarvis/Jaguar twin plug dizzy has MSD guts, so for me it's a plug in.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 02-26-2021, 03:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
A more recent discussion is here;
Best advance curve for SC 180 HP ROW full stock?
Dave
Old 02-26-2021, 09:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
RDM RDM is online now
Coram Deo
RDM's Avatar
After delaying for two years thinking it was something else, I finally ponied up for the CDI+. Installation was 10 minutes (including checking the timing before and after), and the car runs much better. The mid-range stumble when tipping in the throttle is gone now, and the idle is rock solid. Well thought out, well executed product.
I plan on doing the study and locking down the distributor as part of winter projects. Does anyone have a curve they like for an SC with 964 cams and SSIs that I can use as a starting point?
Strangely, my wife believes the car is quieter now, too. Any basis for that? I'll take it either way....
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 08-13-2021, 05:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
Targa_PB_78_SC
mike sampsel's Avatar
marvelous, simply marvelous. Dru.
I'll be watching and learning.
BareRearedRookie
Old 08-13-2021, 02:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
