thrown_hammer's Avatar
Is this Overkill?
My car gets hot during high RPM low speed driving.(Auto-X) I installed some fans to the oil cooler. Does anyone think these will pose a clearance problem? I have the car up on 4 jackstands so I couldn't check. But I will verify clearance issues before I spend time wiring everything.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 05-23-2003, 09:27 AM
the cooler would have to be farther forward than the factory position for the tire not to rub. even the factory louvered panel behind the cooler comes mighty close. no room on the front side? hopefully those fans suck instead of push. they will also get killed by rocks and mud slung off the tire.
206 637 4071
Old 05-23-2003, 09:35 AM
They should be very effective at low speed cooling. Any room to put them in front of the cooler? In this position, they look vulnerable to gravel hits. Do you know if all three fans are necessary? One or two might do the job - three might be superfluous. How about three more on the other side too? Sorry, couldn't resist.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 05-23-2003, 09:36 AM
Shawn,
You have been looking at too many computer over-clocking sites.
Neil
'73 911S targa
Old 05-23-2003, 09:40 AM
Senior Member
Are the fans waterproof?
Joe
Old 05-23-2003, 10:00 AM
Might be able to squeeze one in front of the cooler. Limited space because of the battery box. The fans are pulling air thru the cooler. I may mount one pushing at the front on the bottom and one pulling at the top on the back side.
1975 911S (sold)
Old 05-23-2003, 10:01 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
You might want to consider putting those fans in front of the cooler. I've seen fans melt from pulling the heated air from the cooler. Installing the fans in front of the cooler with the factory stone gaurd in place to protect the cooler and to stall the air long enough to transfer some heat from the cooler to the air would be more effective.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 05-23-2003, 10:28 AM
Automotive Monomaniac
Emission's Avatar
Originally posted by KevinP73
"I've seen fans melt from pulling the heated air from the cooler."
I never thought of that. The oil in the cooler has got to be 250 F. (or so) before it is cooled and sent back to the engine. That temp will soften a lot of plastics.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 05-23-2003, 10:32 AM
nostatic's Avatar
clearly this calls for carbon fiber and titanium. Shall I call a friend at JPL? I think they have a few of these special spec fans next to the $15K toilet seats...
ON a related note, it was fun to watch last week's F1 race during the multiple restarts, with the crews running out to evidently dump dry ice into the system to keep the engines from melting down. egad!
Old 05-23-2003, 10:36 AM
IMO it looks as if the presence of the 3 fans may reek havoc with the airflow thru the cooler at higher speeds.
Warren & Ron, may you rest in Peace.
Old 05-23-2003, 10:37 AM
APKhaos's Avatar
Everything said here is right. Biggest issue will be stone damage. Those plastic fan blades are brittle. One hit and the fan will disintegrate. Need to protect them with a stone guard similar to the stock Carrera setup.
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 05-23-2003, 10:56 AM
Thats why I come here guys. So will one fan in front of the cooler be effective enough? (cause thats all i would have room for in the front)
1975 911S (sold)
Old 05-23-2003, 11:04 AM
tobluforu's Avatar
Yes to the one fan. but do get a good fan. Buy a spal pull fan. I've had one hooked up to the IC on my saab for over a year and it works great. Super tough.
http://www.slickcar.com/spal-fan.asp?offset=40
Old 05-23-2003, 11:23 AM
Hey are you calling my fans...umm...NON good?
1975 911S (sold)
Old 05-23-2003, 11:33 AM
tobluforu's Avatar
Heck no! I have a fan like that one as well sucking air from below my engine compartment and pushing it through a tube, and into one side of my air filter on my saab. But it's not in an area that will be hit with rocks and such. Not as strong as a spal either.
Old 05-23-2003, 11:42 AM
One fan in front(two if I can squeeze them in)of the cooler it is!
Thanks guys.
1975 911S (sold)
Old 05-23-2003, 11:49 AM
disband
juanbenae's Avatar
will you be wiring the fans through the fuse panel or just off the battery with an inline fuse and switch?
Old 05-23-2003, 11:52 AM
I was thinking off the battery with an inline fuse and a small toggle switch. The car runs cool at speed. So I would just switch it on at auto-X's and what not.
1975 911S (sold)
Old 05-23-2003, 11:58 AM
tobluforu's Avatar
On mine, I went down to Kragen and bought a fog light relay kit (15amp fuse). Wired in a switch in the dash that is on or off.
Old 05-23-2003, 12:11 PM
I have exactly the same thing sitting on my shelf in the garage. Hope to have everything wrapped up by the end of the long weekend.
1975 911S (sold)
Old 05-23-2003, 12:13 PM
