Fuel hose size?
I've done some searching and can't find a clear answer on this question.
The fuel line in the picture below, from the bottom of accumulator to return bracket, anyone know the size (ID) of the polyamid hose? Mine has been patched together by the PO using questionable methods and I'd like to replace it.
I am going to purchase the raw polyamid hose from somewhere but I don't know the ID. Is it 6mm, 4mm, 3mm, something else?
The car is an '80 SC w. lambda.
Cheers!
Cortney
Old 04-12-2022, 03:07 PM
Cortney,
The 6-mm ID polyamide plastic tube will work for the fuel accumulator bottom fitting. Are you aware that the polyamide fuel line/s require some special tooling unlike a fuel injected rated rubber hose? While the return lines are under low fuel pressure during its normal operation, it could get as high as 100+ psi. in the event of a return line getting totally blocked or clogged.
Pressure test the newly fab return line at 120 psi. before using it for safety protocol.
Tony
Old 04-13-2022, 09:18 AM
Tony - thanks for the reply with the hose size.
I am aware of the pressures, and will bench test my fix before relying on it in the car.
What special tooling is required?
Old 04-13-2022, 10:22 AM
BoxsterGT's Avatar
Porsche Crest
The Return Line that connects under the Accumulator is 0608, meaning 6mm ID x 8mm OD.....
This is tube very inexpensive to buy but very difficult to install.
I am working on a Main Return for an 80 SC now.....
The Accumulator Line is shown on the Left. This model year has an extra line that connects to the frequency valve.
If any CIS lines are needed I am happy to help, but this requires your sending the Return assembly to me. I have the special tools for this.
You may email me: len.cummings @ verizon.net
but please, NO pm's, my box is FULL.
Len
Old 04-13-2022, 11:19 AM
BoxsterGT's Avatar
Porsche Crest
Here is a better photo of the 0608 Line.....
This is a "one-time" only fitment, as you cannot remove the old tube easily, and fitting the new tube is even more difficult without a fixture.
Have fun.
Len
Old 04-13-2022, 11:23 AM
Cortney,
You are not saving much by doing your fuel line/s. Contact Len Cummings and order the FA fuel return line and not worry about it.
Tony
Old 04-13-2022, 12:14 PM
Guys - thanks for your responses. When the time comes, I will get in contact with Len. In the mean time, I wonder if I can just use a quick connect fuel union?
For reference, here's what I was left with from the PO. Not very confidence inspiring! Interestingly though I'm not having any hot start issues so that tells me its holding pressure...for now.
Thanks!
Cortney
Old 04-13-2022, 02:40 PM
This is easy to do. Have done a bunch.
Here is a snip from the service manual
Here is a home made tool to clamp the line to install the fittings (many other posts on Pelican on how to make and use)
Old 04-14-2022, 11:55 AM
BoxsterGT's Avatar
Porsche Crest
I have a spare factory Tool P385 if you would like to buy this.
Please email me only, NO pm's.
Old 04-14-2022, 12:29 PM
BoxsterGT's Avatar
Porsche Crest For 80 911SC ONLY....
FYI - A bit of info as I remake a set of CIS Lines for a 1980 SC with Lambda.....
This fitting that connects to the Frequency Valve is unique, and I cannot buy this anywhere. The assembly is NLA from Porsche.
This Polyamide line is ONLY for 1980 SC models. 81>83 have steel lines and do not use this.
I am working on a special order of these special and unique Polyamide fittings in case anyone needs a replacement.
For info, please email me.
Old 05-27-2022, 06:50 AM
