Designer King
Paulporsche's Avatar
Is This Air Conditioning Hose in the Wrong Location?
This is a pic of the AC hose under the left side of the car as it is about to go upward into the engine compartment. As you can see it is now located to the outside of the sway bar mount. I am afraid it will get pinched there and I should move it toward the center of the car just to the right of where I am pointing.
What do you think?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-30-2022, 10:58 AM
walt's Avatar
Mine is located just inside the sway bar mount.
Walt
82SC 3.0
81SC 3.6
Old 05-30-2022, 01:08 PM
proporsche's Avatar
that is not a/c hose ..it is your drain for the front hood grille went-fresh air unit ..for water..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-30-2022, 01:32 PM
Designer King
Thanks Ivan. The hose is on the right, held by the clamp. Where I'm pointing to (not quite) is an upward depression in the floorpan near the left rear wheel. I'm going to run the line there similar to Walt.
Thanks Walt.
Paul
Old 05-30-2022, 01:40 PM
proporsche's Avatar
silly me and blind;-) yes as Walt said i have it on the inside......i just looked at you finger not the rest of the car;-)
Ivan
Old 05-30-2022, 01:45 PM
Designer King
No problem. Ivan. Thanks for replying and confirming.
Paul
Old 05-30-2022, 03:45 PM
