Turn Signal Mystery
Returning from the Targa California yesterday from Paso Robles to Scottsdale, my turn signals quit working. About 6 hours into the trip, it was a bit hot coming across from Blythe into AZ, I stopped for less expensive gas just inside AZ. After that stop, not sure when, turn signals simply would not work. No flash from the green arrows. Stalk feels the same either way.
About an hour later when I got into metro Phoenix they were working again. This happened once before. Any ideas? Heat (was only around 90 so not excessive heat)? Otherwise the car was running strong. Car is a 1969 912 chassis updated to an RS Clone with an '86 3.2L.
'86 944T black/red, chip, fuchs 8's and 9's- Sold '97 Boxster silver/red, big mistake - Sold '99 C2, silver/black, RoW M030 - sold "69 912 white w/ '86 3.2L (like the pic, just not the pic) |
I had problems and was told to check the fuses and make sure the contacts are clean. I also replaced the left front and right front fuses when I was at it. Is your flasher relay good?
Thought about that. Have changed the original box to the blade type, so all good on the fuse side.
Check the grounds on the system.
It may well be the relay itself.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Where will I find the grounds? Will check the relay as the flashers don't work
Do have a wiring diagram for your car? It might be that the flasher relay is fused, so you need to check your fuses as the first thing to do. Is the flasher relay getting power? Check with a test lamp or meter.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
would anyone have a photo they could post of the turn signal relay and flasher relay in place?
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
relay location.
^^^^^ For our '86. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
![]() ![]() Am I right in assuming the black relay is the turn signal? Can someone help me with the round relay? Wherle part number 901.615.109.01
Is the relay not behind the fuel level instrument? Pull out and you will see it,
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
