-   -   Permanent live too my MSD (http://forums.pelicanparts.com/porsche-911-technical-forum/1119862-permanent-live-too-my-msd.html)
den912 05-30-2022 12:38 PM
Can I take the permanent live to my MSD from “fuse box 3 in the engine bay” or will this put too much load on the fusehttp://forums.pelicanparts.com/uploa...1653939522.jpghttp://forums.pelicanparts.com/uploa...1653939560.jpg
Showdown 05-30-2022 01:21 PM
Totally fine.
den912 05-30-2022 01:33 PM
Is going past the fuse correct or before
Showdown 05-30-2022 02:10 PM
I have mine before the fuse with an inline fuse to protect the MSD unit. If you put it after the fuse you may have to change the fuse to a higher amperage but that’s probably not advisable.
rwest 05-30-2022 04:57 PM
I ran mine like that for years without issue, although many will tell you to run a line off the starter.
icarp 05-31-2022 07:03 AM
What I like to do for power in the engine bay , is run a 10ga from the starter battery cable to the engine bay. At that point I can run a relay for ignition hot or just constant hot . Fuse as needed .
Ian
AlKidd 05-31-2022 09:08 AM
Why do you want it hot at all times? I ran mine through a relay thats switched on with ignition.
icarp 05-31-2022 09:12 AM
The MSD wants the primary + to be hot all the time , then the internal MSD switch activates with the key to make the system hot .
