74 911 - Where is my fuel pump relay?
I am having intermittent running problems and thought to check fuel pump relay -and its not on the fuse box -just the horn and foglight have a relay
something amiss? or not on the 74's
tnx much rq
Old 06-08-2022, 09:00 AM
Functionista
manbridge 74's Avatar
None exists. Not a bad idea to add one.
I’ve been wanting to add an inertia switch to mine. From an old Ford Explorer or the like, it would turn off fuel pump in an accident where a guy couldn’t get out (fuel pump runs with key in ON position on 74).
Old 06-08-2022, 09:17 AM
Odd that Porsche thought it unnecessary for one. bean counters?
when I first bought my car over 10 years ago I had various problems with the key switch - in fact one time it actually started the car without the key in at all! - I replaced it right away of course
Wondering now if the current running through the key switch degrades the contacts when wired like that - because currently I am having intermittent cut out while running
Old 06-08-2022, 09:31 AM
Functionista
In 1974 they continued to use the same wiring configuration used on carbureted cars. The reason is unimportant, only that all car makes/models have certain deficiencies that can be improved upon.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-08-2022, 10:39 AM
ROW '78 911 Targa
timmy2's Avatar
76 was the year they added the FP relay and safety switch.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-08-2022, 11:01 AM
OK tnx for that - I thought maybe they deleted it because a friend has a 73 with a pump relay
Old 06-08-2022, 11:11 AM
Functionista
Relays have been known to be added after 50 some odd years.
Jeff
74 911, #3
Old 06-08-2022, 01:57 PM
Warren Hall Student
Bobboloo's Avatar
There are several electrical updates that should be considered for early 911's.
Here are a few.
1. Relays for the headlights (Unless you like paying stupid money for a new switch)
2. Fuel pump relay. (Your ignition switch will thank you.)
3. Fuse the 12v + wiring for the gauges. ( Unless you you like the cool looking smoke coming out of your dash.)
4. The brake lights circuit doesn't have a fuse so maybe this was a safety issue? Although having it unfused doesn't save you when the switch is broken so I can't really follow that logic.
I'm sure there are others but those come to mind.
Old 06-08-2022, 09:00 PM
