G50 5 speed input shaft compatibility?
I've got a SBH N/A G50 fitted, think it's a /01 - from a 3.2 anyway.. Over time, I've collected all the gearsets from a G50/50 except 1st. Because it seems very short-geared and horribly buzzy when you make healthy amounts of torque in a light car.
I've been offered a G50/50 input shaft with the desired 41:13 gearset - bonus, already shortened. Seems too good to be true.. Will a G50/50 input shaft fit into an N/A G50 transmission, or is there anything else incompatible/needs to be changed? Or is this just entirely incompatible? I'm concerned intermediate case length (longer for the bigger ring & pinion on the /50, right?) might cause other "stuff" on the shaft to be different - but I don't even know enough to be dangerous here, and there's all sorts of other things that could be issues as well... |
It’s not going to be the right length. Even shortened it will still be over an inch too long, because of the ring gear diameter. The delta between an NA and a Turbo is in the differential case.
I happen to need a 1st gear set for a G50-50 for my own car.
PM Sent |
Matt, thanks for the reply, appreciate it.
| All times are GMT -8. The time now is 04:24 AM. |
