I want 225hp, how to get there?
Hey everyone,
I'm thinking 225hp (crank) would be a nice amount for a driver that I can have some fun in. Not a track car but may hit Road Atlanta once in a while seeing as I live about 8 miles from the track.
The car,
1979 SC, California car (if that matters) 172hp. Completely stock 3.0 with the exception of a M&K Cat Bypass pipe, air pump removed and CIS. I believe it has 8.5-1 compression.
The car has 78k and last year the PPI showed 2-3% loss across the board and the car currently runs great but, I have no basis to compare.
How would one go about reaching the 225hp goal in this situation?
I'm already planning on going with CDI+ and SSI (not sure on muffler) exhaust but would like to stick with the CIS for now as I've read that CIS can handle 250-275hp, not sure if that's accurate.
Would cams and higher compression pistons do the trick? Can I get just higher compression pistons or would I need to get the cylinders worked over?
I would be great if I can accomplish this without splitting the cases.
I do see PMO carbs or ITB fuel injection in the future but would like to do that later.
Thanks!
1979 911 SC Gran Prix White. Gone but not forgotten.
2016 GT4, current steed.
IG @hulley31
Old 06-20-2022, 07:51 AM
I’m new to the forum but from the info i’ve read the Euro Spec 3.0 engine will get you pretty close to 225hp. I will certainly be following the thread.
Old 06-20-2022, 08:10 AM
Yep, that's what I was thinking, I seem to remember reading the euro spec motors were 9.8 to 1 with around 207hp, I could be wrong on that, and I figured with pistons and cams along with the CDI+ and SSIs just might get me there.
IG @hulley31
Old 06-20-2022, 08:19 AM
shoooo32's Avatar
Early SC CIS is pretty easy to tune for HP. One of these days I need to dyno my 1978 targa (98mm P&Cs, 9.5:1, 964 grind cams, SSIs) but the butt dyno says 230hp. If I built it again today I'd definitely use William Knight's M1 cam.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 06-20-2022, 09:09 AM
Bill Verburg's Avatar
98mm Mahle 9.8p/c,, ssi + good muffler and cams ought to do it
if retaining CIS get the cis version of the pistons
Bill Verburg
Old 06-20-2022, 09:22 AM
98mm is for a 3.2 conversion, right?
IG @hulley31
Old 06-20-2022, 09:34 AM
correct
for most street use a btter torque curve is more important than top end hp
Bill Verburg
Old 06-20-2022, 09:40 AM
Jameel's Avatar
When I rebuilt my 3.0 (small port) a few years ago I did the SSI's and the 964 Cams. (But I'm intrigued by the M1 cam....I'll be listening if the discussion goes in that direction. )
I used the stock cylinders (plated with Nikasil) and bumped up compression with Max Moritz style pistons from J+E. To compare, my brother's mostly stock '79 SC (haven't touched the engine, just did SSI's) was peppier than mine even with all those mods (big ports make a difference) That said, I put a Kennedy lightweight pressure plate on a couple months ago and man that made a huge difference in the feel. Much more revvy and exciting to drive. I would not want a 911 with a stock pp. The lightweight one didn't affect street driving at all (spinning down too fast and being a pain to shift I mean) and did nothing but make the car more fun to drive.
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 06-20-2022, 09:53 AM
correct
Would this be possible maintaining the stock cylinders and just higher compression pistons?
IG @hulley31
Old 06-20-2022, 01:04 PM
Probably
here are some stock engines
930/18 aka SC/RS 3.0, S cams mfi 10.3 cr250hp@7000 188lb-ft@6500
930/02 76 Carrera 3.0, 3.0 basically an SC w/ better tune , 200hp@6000, 188lb-ft@4200
930/10 83 SC(RoW) 9.8cr 204hp@5500 190/lb-ft@4300
'84 Carrera 930/20 10.3 cr 3164cc, 231hp@5900, 209lb-ft@4800
so a 3.0 95mm bore w/ cams, sssi+muffler+ignition tuning 9.8cr ought to be in the low 220 hp area
It's just that there is no replacement for displacement on the street
that's' why so many have gone for a 993 3.6, stock 272hp@6100, 242lb-ft@5000, 11.3cr, knock sensors just in case gas is poor
Bill Verburg
Old 06-20-2022, 03:40 PM
I recently dynod an 80 SC
98mmJE 9.5:1 comp w new nickies
20/21 web cam
SSI’s
CIS
It only made about 170hp to the wheels. Checked on 2 different dynos very surprising. The car drove like a bat out of hell though much quicker than a stock sc.
it's not leaking....it's just marking it's territory
Old 06-20-2022, 06:03 PM
GaryR's Avatar
Send a message via ICQ to GaryR
20/21 web cam
SSI’s
CIS
That does not sound right.. you may want to look into you cam and ignition timing.
Gary R.
Old 06-21-2022, 12:16 AM
Eva
911SauCy's Avatar
20/21 web cam
SSI’s
CIS
Either the dyno is broken or you had the wrong car on it...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-21-2022, 04:42 AM
(man/dude)
Jonny042's Avatar
It's not answering your question, but a more reliable and predictable way to get better performance is to change the gearing in 2nd through 4th gears (leave 5th alone for cruising).
SSI's and a muffler will make it sound like it has 250Hp!!!
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 06-21-2022, 04:54 AM
Eva
911SauCy's Avatar
Hey everyone,
The car,
Thanks!
Interestingly, I started with a '78 Targa, of the exact same spec, 11 years ago...and began down the slippery slope with similar mods you've mentioned.
I ended up going down the hot rod road and hunting for a euro 3.0, which I was grateful to find a freshly rebuilt one on here. That motor currently has Dougherty Cams "964 RS Spec", headers, M&K exhaust, and some other small basics, running strong on stock CIS... making 212whp on a Dynojet.
Your instance of a low mileage car with great leak downs so I'd imagine that a motor swap wouldn't be in the cards.
My opinion would be to build the top end to euro spec, P/Cs, maybe a little head work, and some mild cams would really run amazing.
Last $.02, PMO Carbs are really great when tuned properly. CIS is more solid and robust than carbs, just not as sexy. The ITB Juice isn't worth the squeeze. Before you consider blowing 15-20k on ITBs, do your homework on your ROI.
Old 06-21-2022, 05:02 AM
I am my 911's PO
'78 SC's Avatar
There's a good discussion of this topic here.
Old 06-21-2022, 06:05 AM
The early SC’s (U.S. spec) I’ve driven and been a passenger in all seem to be very quick. I suspect maybe Porsche was conservative in their power figures for some reason? There is a C&D road test of a ‘78 SC targa that was basically as fast as a later 3.2 Carrera. The later small port “emissions friendly” SC’s seem to have gained a few mpg, but lost some power.
It would be nice if a factory Porsche 911 engineer from that era could provide some insight into the early vs late SC power differences. Could the large ports and higher flow fuel distributor (even with 8:5:1 CR) really make that much difference? I could believe Porsche provided C&D a 3.1 “special,” but all of the early SC’s I’ve been have all seemed to be very quick…
Old 06-21-2022, 08:01 AM
Eva
911SauCy's Avatar
Not an engineer but you're accurate regarding the 78-9 Big Port motors. I know that a local race shop who is very successful in the Air Cooled Cup series, prefers to build their race motors using a base of a "big port" motor
Old 06-21-2022, 08:52 AM
Here's a data set for air cooled 911
earlier list I forgot the '74 Carrera 3.0RS
3 liter, S cams MFI 230hp@6200 206lb-ft @5000 9.8 cr
to build a close modern rep. of it
9.8cr Mahles, TBI, Motec, S cams, SSI +muffler
I wouldn't change the gearing as it was pretty appropriate for the rev range and weight of these cars, It wouldn't hurt to have 225/45 or 245/45 x16 or 225/50 or 245/45 x15 tires in back
Bill Verburg
Old 06-21-2022, 09:47 AM
An older Mustang GT with a 5 speed will do it.
Old 06-21-2022, 10:37 AM
