Halm's Avatar
Brake Switch Adjustment
Interesting morning having my car go through State inspection! Among other problems, they didn't know how to open the engine compartment, wanted to add oil while the car was cold and turned off (hand brake was on), etc, etc. You get the idea.
In any case, I really need to adjust my foot brake switch so the brake lights come on sooner. A quick look through Wayne's 101 Projects book was not much help. Will it be pretty obvious how to adjust the switch when I get into the pedal cluster?
'17 Cayenne
Old 05-30-2003, 05:47 AM
Cool
the switch is triggered by the switches on the master cyl.. do a search on this one.. some guys recommend changing both switches and crossing your fingers...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-30-2003, 08:28 AM
I think on the earlier cars, the switch was activated by pedal movement.
Tim
Old 05-30-2003, 08:44 AM
Early_S_Man's Avatar
Porsche Crest
Boosted brakes got the master cylinder switches ... earlier cars have the pedal switch. Rebuild of the pedal cluster might be a good idea if there is excessive play at the brake switch.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-30-2003, 10:00 AM
