Born to Lose, Live to Win
Fuel latch lid closing issue
Ever since I had my 83, when I’m done fueling and go to close the lid, I have to reach inside and pull the release in order to get the lid to latch shut
Is this abnormal? If yes, what’s the usual cause of this? I’ve never put force on the fuel lid so I’m not sure if it will latch itself closed if I put some weight into it, not sure how much force is normal etc.
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
I used to smash it down with my fist, then thought better of it and after a resto, and started using your method as you described.
Jason
'79 911SC Targa |
John W
I just need a slight push on my 89.
Not normal. Should be able to just press it closed.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
It may not be normal, but many at this age have the same issue. Continue what you are doing so you don’t mistakenly bend the latch tab.
Is the reason why it doesn’t close normally likely due to a bent latch tab? Everything appears to look normal.
(man/dude)
Same here!!! I wouldn't say it's the best design. I'd rather relieve the stress on the assembly in the manner described, which beats the alternative of bending something and not having it latch at all!!!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
