Brake master cylinder
Hello,
during the weekend I meant to finish my brake upgrade. I have 928 S4 front calipers and 12" VCI front disc in front and 964 front calipers and 930 discs on the rear. I also have new master cylinder (Mercedes truck ATE part #3.2123-1003.3), but when I put in place, the outer brake fluid feeding line is in direct contact with the rubber on the steering rack. As I know a whole bunch of members here has done the same mod, so how did you solve the question? Car is 911 Coupe -74. KH |
Master
If somebody could post a picture of new master cylinder mounted.
KH |
Why didn't you just use a Turbo MC? Direct bolt on, unless this shares the part number with Mercedes.
The ATE 23mm m/c is a very close fit. I believe that the later al. Carrera style crossmember is highly recommended(if not mandatory) also bump steer rack spacers will help. Are you using a 45° or 90° adapter at the front feed?
Here is a pic from the archieves; and another This one is using metal 90° fittings but usually plastic 45 & 90 is supplied w/ the kits. The turbo m/c is only applicable to boosted installations.
I did 2 things:
1- heat the metal end of the feed line and changed the angle slightly with a tube bender. 2- installed the rack spacers. Paul
My ignition is retarded. |
Just got in from 2 days of sailing in the rain, my head is still rocking. The feed line is at the top in pic 1 it uses a plastic, non pressure line that fits into a rubber grommet, the 90° fitting and rack spacer (and maybe the alloy crossmember) are all that s needed. Ignore the part in my last post about the metal 90 that is a pressure line.
