-   -   Magnesium passivation products (http://forums.pelicanparts.com/porsche-911-technical-forum/1120999-magnesium-passivation-products.html)
fizeus 06-16-2022 02:11 AM
Hi all,
can anyone tell which products are available in EU to passivate magnesium.
I have to restore a fan shroud with the correct process and I do not want to put paint on it.
Bonderite is one of the most used but it's impossible to find at human prices.
Dpmulvan 06-16-2022 05:27 AM
Aircraft spruce has quarts for $35. Check with local aircraft supply places.
Missed Approach 06-16-2022 07:03 AM
Hi Fizeus- To avoid confusion, Alodine 1201 (now known as Bonderite MC-R 1201) is for aluminum alloys only, not Mg Alloys. Your fan shroud was an AZ31/AZ91 Mg Alloy, so (as you've already discovered) the Henkel Bonderite M-CR Magnesium Aero Conversion Coating 598970 is still the best option for an actual conversion coating. Unfortunately, prices have certainly climbed! A lower-priced alternative is certainly a spray like Gibbs Brand or Boeshield T-9. Sadly, these will not give the appearance of the factory conversion coating. However, if you review the forum, you will find that many have been pleased with the protection offered by either of these two sprays.
Hope this helps!
Arlo911 06-16-2022 07:45 AM
Hi Fizeus, I think you will have a hard time finding anything for home use here in Europe. If you do please let me know :)
I see you are in Italy, why donīt you contact Marvic Wheels, they manufacture magnesium parts so should be able to help?
Missed Approach 06-16-2022 07:59 AM
^^^ Great suggestion Arlo911!
Missed Approach 06-16-2022 10:15 AM
Hi Fizeus and Arlo911- As an aside, I checked with a former colleague and he mentioned the following Italian and French companies as possible Conversion Coating options for the EU...
Galvair SRL 10 V. EDISON, Barberino Di Mugello, FI 50031, 50031 Barberino di Mugello FI, Italy
+39 055 842 0198
And Modertech-
https://www.modertech-industries.com/index.php/traitements/traitement-sur-magnesium
Hope this helps!
Arlo911 06-16-2022 10:54 AM
+39 055 842 0198
And Modertech-
Hope this helps!
Thanks, I will check them out! Man this forum keeps amazing me even after all the years I've been on it :)
fizeus 06-16-2022 02:46 PM
+39 055 842 0198
And Modertech-
Hope this helps!
Missed Approach, thank you for your suggestion... they are very useful.
1 quart of bonderite M-CR in italy has been quoted about 1000,00 € :eek::eek:
so I think I'll contact aircraft spruce at first to see if they can ship to Italy (THANKS to Dpmulvan), I'll also contact Galviar and Modertech to see if they can help.
I really agree with Arlo911 about the wonderful people and high quality of help offered by this forum participants !!!!
REaaly thanks again to everyone !!!
Trackrash 06-16-2022 03:27 PM
Not sure if this relates, but I used a chromate conversion from Caswell. Caswellplating.com. Gives that subtle amber tone. Followed by a coat of Gibbs. Not sure if it can be shipped to Europe.
http://forums.pelicanparts.com/uploa...1655421286.jpg
