Born to Lose, Live to Win
ramonesfreak's Avatar
Fuel latch lid closing issue
Ever since I had my 83, when I’m done fueling and go to close the lid, I have to reach inside and pull the release in order to get the lid to latch shut
Is this abnormal?
If yes, what’s the usual cause of this?
I’ve never put force on the fuel lid so I’m not sure if it will latch itself closed if I put some weight into it, not sure how much force is normal etc.
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 06-19-2022, 07:04 PM
I used to smash it down with my fist, then thought better of it and after a resto, and started using your method as you described.
Jason
'79 911SC Targa
Old 06-19-2022, 07:48 PM
John W
I just need a slight push on my 89.
Old 06-19-2022, 09:18 PM
pete3799's Avatar
Not normal. Should be able to just press it closed.
Pete
79 911SC RoW
dreichman's Avatar
It may not be normal, but many at this age have the same issue. Continue what you are doing so you don’t mistakenly bend the latch tab.
Old 06-19-2022, 10:14 PM
Is the reason why it doesn’t close normally likely due to a bent latch tab? Everything appears to look normal.
1983 911sc
Old 06-20-2022, 04:24 AM
(man/dude)
Jonny042's Avatar
Jason
Same here!!! I wouldn't say it's the best design. I'd rather relieve the stress on the assembly in the manner described, which beats the alternative of bending something and not having it latch at all!!!
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 06-20-2022, 05:02 AM
