Tires got mounted - 235 in front, 275 in rear
![]() Quilted engined bay sound pad and the rear suspension starts to go in ![]() And finally - my partner in crime fitting the front Brembo GT brakes. ![]() Our plan over the next few days is to finish the rear suspension and brakes and get the car rolling. Then we will keep plugging away at the wiring (fusebox is already wired and gauges getting there), Classic retrofit Electric A/C, oil cooling upgrades and then start to put the interior together. I'll try to do a little better updating this thread! Last edited by sgroer; 10-23-2022 at 06:38 PM.. |
Registered Minimalist
awesome update! Keep going!
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Awesome build and great pics as well. Keep it coming! Bill |
Very cool, my boy is 4 but hoping to do the same some day. Keep us updated!
'86 3.2 Carrera Coupe Iris Blue '84 944 Grand Prix White(sold) |
Subscribed. Great build, that rear pad looks top notch, is it heat rated? Small details like that always get my vote.
I wish it was more complex, lol… Sonderworks. $299 and came in 3 days. You can pick the stitching color and the fit / finish of it is insane!
Man, looks like you guys are going a million miles an hour!
I hope you're planning on pulling the studs out of all the hubs and chucking these in the lathe to clean up mating surfaces. If they're assembled like this you'll run into loose rotors and wheels with the first real bit of brake heat. |
We are definitely making progress. We have been fortunate to have great people helping us and the stars have aligned on all the schedules for the work we outsourced. Is your concern the wheel studs (they were masked off) as well or the just the hub / rotor mating surface? Last edited by sgroer; 10-24-2022 at 08:57 AM.. |
Be sure the contact points on the fan housing are sanded bare so that the alternator can ground itself properly through the housing to the case.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Wow looks really great! Looking forward to seeing it driving in Chattanooga soon!
Suggest 993 mirrors.
1980 911 - Metzger 3.6L 2016 Cayman S |
Thank you for the heads up. We did mask all of that but I am going to check it all to make sure! Kind of important. Haha.
You really are moving quick! ![]() Glad to help! I'm usually quiet, but safety is important. |
Insert Tag Line HERE.....
Hey Sean! Somehow I missed this thread…. I’m a Smokies GT member also! Looking good!,
Marc |
Hey Marc! You coming to Smokies GT 2023? An air cooled event for current Smokies members is being discussed right now as well.
