-   -   New hard lines don't seem to fit--why? (http://forums.pelicanparts.com/porsche-911-technical-forum/1121337-new-hard-lines-dont-seem-fit-why.html)
911SCRVA 06-23-2022 04:22 AM
Interesting option. Do you know who custom makes them?
Originally Posted by mepstein (Post 11724333)
You could always have the correct size soft lines made to fit.
Showdown 06-23-2022 06:00 AM
Fitting the connections while everything is loosely attached to the car is the way to go. I spent way too long fighting my lines when installing the carrera cooler with everything bolted down tight until I loosened all the attachment points and then it all went together easily.
rokemester 06-26-2022 06:10 PM
I know using a sealant is controversial. I did not use Teflon plumbers tape, although it appears so. I used a oil pipe “dope” the guy who inspected my oil cooler recommended. In his many years of experience this material has worked well. We’ll see, fingers crossed.
rokemester 06-26-2022 06:26 PM
http://forums.pelicanparts.com/uploa...1656292741.jpg
This is what I used. So far so good. It’s been a couple of years.
