Front ride height
I have reassembled the front suspension and the ride height seems very low. I tried to adjust it on either side by tightening the 11mm adjustment bolts, but even with them fully tightened the height is still very low. I am thinking that I may not have put in the torsion bars correctly or something. Do the front torsion bars have anything to do with ride height and if so how do I adjust them?
Bob Springer
1978 911 SC (Almost Finished)
http://www.noh2o.com
Old 05-27-2003, 12:33 PM
Certified Pre-Owned
BGCarrera32's Avatar
You need to jack the front of the car up, pull wheels or crank to one side so you can get at that bolt you tightened, remove the bolt, pull off the little splined arm it goes through, replace the little arm one spline counterclockwise (I think) if we're talking the pass side wheel for instance, insert bolt, readjust.
After doing, roll car back and forth a foot, bounce front bumper once or twice to settle car.
Recheck with tape measure...
-BG
'84 Carrera Coupe
Old 05-27-2003, 12:42 PM
Cool... Thanks. Bob
Bob Springer
Old 05-27-2003, 12:45 PM
Irrationally exuberant
ChrisBennet's Avatar
I think you may have to roll the car back and forth a bit more than that. I'd back out into the driveway and drive back into the garage at least.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-27-2003, 01:03 PM
Certified Pre-Owned
Heck while you're at it make a beer run and then come back and reinspect.
After a few beers that night (car parked of course), the ride height might correct itself...
'84 Carrera Coupe
Old 05-27-2003, 01:33 PM
n8marx's Avatar
I'd drive it even further than that. When I lowered my front end I drove it for 100 miles and rechecked the ride height then had it aligned. 300 miles later the suspension settled an additional 1/4 inch. I think my car is possessed.
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 05-27-2003, 01:35 PM
Eric Mckenna's Avatar
B double E double R. U. N beer run!!!!!!!!
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 05-27-2003, 02:43 PM
Already had the beer so up and down the driveway it was. That did the trick. Thanks again for the help.
Bob Springer
Old 05-27-2003, 04:38 PM
