Question moulding/trim won't stay sealed
Circled in blue you can see the moulding coming off the body. Any tips on replacing the rubber stopper/fastener that holds down the moulding through the adhesive seal and into the body? I've tried a couple adhesives, but nothing is keeping this piece of moulding from popping back-up. My next attempt will be with butyl tape.
The adhesive seal dried out and flaked off, and the rubber stopper/fastener holding the trim down into the body deteriorated. I haven't had search-luck on finding an answer on this topic in the forums or on the web.
Old 06-17-2022, 08:08 PM
New-ish 911SC Targa Owner
pampadori's Avatar
That trim on a targa has a fastener that is accessed from inside the wheel well.
To remove it completely the glass has to come out. So hopefully you can simply add the missing nut.
Old 06-18-2022, 04:38 AM
Discseven's Avatar
5 minute epoxy gel. It will take some degree of expansion & contraction and vibration. Don't think regular epoxy will survive there. Trick is the surfaces that make contact need to be extremely clean for this to make & keep contact. Gel is good to work with as it doesn't "flow."
To be sure, we're talking about part #18 below. Sounds like your #20-21 are gone... and the prong???
5 Minute gel sample:
Am not promoting this brand. I do happen to use this stuff. Excellent adhesive as far as I'm concerned.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-19-2022, 05:47 AM
Thanks for the tips! Sealant that ‘flows” is not fun.
This is the part and number: emblem retainer W99959142303. This lil piece keeps the moulding/trim seated.
Once my 911 was on the lift I did not need to remove the tire. The tire sagged down enough. Looking up above the tire and into the fender, I could see the hole where the moulding trim pin fits once pressed down. I was able to place the emblem retainer in the hole and press the trim down into it. I was not able to see the pin, but could place the retainer by holding it in place.
Old 07-02-2022, 11:18 PM
