Un-sieze G50 Clutch With Motor Out Of Car
I have an '86 Carrera with a G50 and 3.6 swap.
I pulled the motor in the fall to have the tranny re-built. I am re-assembling and the clutch seems seized. I am not 100% certain it is the clutch and not a re-assembly issue (transmission is mated).
Is there a way to try to un-seize/test to see if it is seized without the motor in the car? Without pulling tranny off?
How can I un-sieze with motor out of the car?
Thanks guys
the third foot™ adjustable heel/toe pedal is back!
http://www.wingsaircooled.com
https://youtu.be/U0PZbc55gqw
Instagram: @wingsaircooled
Old 06-28-2022, 03:56 PM
(The motor sat in a reasonably humid garage so this does make some sense, then again it has sat in the same garage for a number of winters with no issue so kind of odd now)
Old 06-28-2022, 04:03 PM
Are you sure your clutch release bearing fork is properly installed?
Bruce
Bruce
That would be the first thing to ask.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-28-2022, 04:08 PM
The disc may have rusted to the flywheel or pressure plate or both. 4 nuts and the trans is off, 9 bolts and the clutch is off.
206 637 4071
Old 06-28-2022, 04:23 PM
I am not 100% sure the clutch fork is installed properly. Here are a few pictures and I will read up on that now.
I would rather not un-mate the tranny. Easy to remove but mating took me a lot of time.
I should be able to disengage clutch with pry bar on the fork, correct?
Thanks again guys.
Old 06-28-2022, 04:36 PM
The fork is engaged but there is clearly something wrong with the TO bearing You can see that the belville spring is bent by the fork
Pull it apart and assemble it correctly
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 06-28-2022, 04:54 PM
lake wales fla
Agree with removing and inspecting everything, brg preload washer has a problem and the fork fingers need lubrication. Looks like the clutch fork shaft boss has been repaired so previous failure of the case. Muuuch easier now than later. Richard
Old 06-28-2022, 05:47 PM
Have tried pulling the transmission back off the motor twice now to no avail. It gets loose and separates about 1/4" but will not come off.
Any ideas? Pin is removed and everything. Driving me nuts.
Thanks guys
Old 07-05-2022, 06:31 PM
Sucess.
Saw something peeking through the pressure plate
(see next post)
Old 07-07-2022, 06:05 PM
Ok for some reason I suddenly can't post pictures. But there was a big hunk of metal in there. I will try again later to post a pic.
Old 07-07-2022, 06:18 PM
917_Langheck's Avatar
If your file size is greater than 5MB then it won't load into the program and post.
Old 07-07-2022, 09:21 PM
Yeah it wasn't that. It was loading and I was getting the image link, but when I posted it was blank. Seems to be working now. WTF is this?!?!?!
Old 07-08-2022, 07:04 AM
All I can think of is maybe a piece of the mechanical stop from an old rubber hub disc that remained stuck in the pressure plate. Don't have one here to check.
206 637 4071
Old 07-08-2022, 04:10 PM
Could definitely explain why the clutch wasn't disengaging.. Except the fact that its been in there all along
Old 07-08-2022, 06:53 PM
I don’t believe u can release the clutch with a pry bar on the bench. A little more background please. Was this a working clutch before removal for trans rebuild. When the trans was rebuilt did u remove the clutch from the engine. Progression of events isn’t clear to me.
Old 07-09-2022, 02:31 PM
Hey @Gled49
Clutch was in perfect working condition before transmission failure. I did not remove clutch until after I re-installed the transmission and found the clutch wouldn’t disengage (via clutch slave, not pry bar). I re-removed the transmission on Thursday to figure out why the clutch wouldn’t disengage, and found the above hunk of metal in there.
My question now is where did that pierce come from and is it essential to clutch operation?
Old 07-09-2022, 06:50 PM
Looks like part of the clutch hub examine it very carefully and I think you'll find it
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 07-10-2022, 06:47 AM
