5 blade to 11 blade fan question
Hi all,
After discovering a seepage between cylinder/head (posted here: https://forums.pelicanparts.com/911-engine-rebuilding-forum/1119832-cylinder-head-leaks-need-your-opinion.html) I made all the check to ensure that the engine was ok (checking compression leak, retork nuts, verify mixture, check ignition). And I decided to install an 11 blade fan instead of the 5 blade on.: ![]() ![]() I noticed 3 things: -better cooling (that was expected) -less noise -less performance For the last point, I wasn't expected that much. And I guess by having less noise it amplifies rhe feeling of having less horse power. So my question is simple, dontou have any idea of how many horse power do I loose when I changed the fan? Thanks! Regards; Thomas |
0 HP lost
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Since you checked compression I would verify all your plug wires and distributor cap are fully seated.
Walt 82SC 3.0 81SC 3.6 |
Difference in flow volume between 5 and 11 blade fan is 9% at stated rpm. Lots of discussion on hp gain/loss and cooling in old threads.
997doesn't have a fan 993tt may be the what was meant
IF the 5 blade fan pully is retained the ratio is 1.8 and flow will be 1539 l/s 21.7% more air flow @6000 than stock
It really would have been better to also have used the same rpm figure as a constant instead of a relative variable. Last edited by 917_Langheck; 07-11-2022 at 03:28 PM.. |
Hi All,
Thank you for your feedback. So from what I understood, the difference of performance should be from 0 to close to nothing. So the lack of power is probably due to a engine that it is less noisy. Thanks |
BTW check the number of fan blades used here: https://robbreport.com/wp-content/uploads/2017/08/83.jpg
In those old threads I previously spoke to, power loss/gain is not necessarily 0, but also not necessarily large, but measurable, or at least calculable. I believe Grady Clay put up a series of numbers on the subject. Last edited by 917_Langheck; 07-11-2022 at 06:11 AM.. |
From what I remebered, After a certain number of RPM, having less blade is more efficiency (from Henry Schmidt if I do remembered).
I also read that from 5 to 11 it consume 3/5 HP. But I am not sure about those information |
Certainly never thought of a drain on power. Learn from Pelican every day.
Sean M '77 911S Targa Ice Green |
Until someone has taken their car to a dyno with evidence of 3 consistent pulls with the 5 blade and 3 consistent pulls with any 11 blade I will find it hard to believe a 3/5 hp loss.
I have a 5 blade still on my 76. I have purchased an 11 blade but haven’t installed it yet.
The worst temps I see in summer are 210 degrees. |
It is like you regarding mine. But I suspect that even if the oil temperature doesn't go that much, 5 blade does not cool well head which cause the engine to expand more.
So I suspect the loss of power is essentially because the engine make less noise thanks |
It's a 914 ...
Engine driven fans do consume measurable hp. We can infer this from the SAE vs DIN hp ratings that Porsche used to do back in the day. DIN allowed for hp measurement to be done while driving the ancillaries from another source. For an early 911, the only ancillaries were the alternator and fan (I assume they tested a non-AC equipped engine).
Consistently 20 hp different between DIN and SAE ratings on early 911s, which I take to mean the fan + alternator consumes ~20 hp at peak hp RPM. Hard to imagine there's enough of a difference between a 5 vs 11 blade fan to be noticeable to the butt dyno. |
A 70 amp alternator would hardly consume 2 hp when fully loaded at highest RPM. That leaves 18 hp only for the fan. That is high power loss.
It's a 914 ...
Yeah they consume substantial hp at high RPM. If someone has better info, I'd love to see it.
