smarjoram's Avatar
PET cd parts confusion - valve covers/studs
Hello, I'm in the process of adjusting the valve clearances for the first time. Unfortunately a couple of studs came out on the lower cover by the premuffler - the nuts had rusted on. I managed to free one by double-nutting, the other however was so tightly stuck that I bent the stud trying to free it.
Looking at my PET cd for the part number I noticed that it says it's a BM8x35 stud whereas the ones that came out are clearly 50mm long. Is there a special way of measuring studs?
I need some more studs for the chain covers to replace the long ones left when I removed the smog pump and that has been equally confusing.
Are there known errors with this cd or am I just stupid? If anyone knows exactly what I'm looking for I'd appreciate the help.
I have a 1981SC with turbo valve covers adn carrera chain tensioners. Here's a pic showing the studs in question...
'81 SC
stefanmarjoram.com
sketch blog
flickr
Old 05-27-2003, 04:22 AM
Irrationally exuberant
ChrisBennet's Avatar
I noticed that. I think they just call out the exposed length of the stud. You aren't crazy.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-27-2003, 04:28 AM
smarjoram's Avatar
Aha! You're right - it all makes sense now, thanks. The good news is that part 5a which held the pump on is the same as the bent stud form the valve cover. Now I just need to find two BM8x42 studs for the chain cover.
'81 SC
stefanmarjoram.com
sketch blog
flickr
Old 05-27-2003, 04:46 AM
Early_S_Man's Avatar
Porsche Crest
What I did, and many others have done ... to expedite the repair ... is to get a DIN 8.8 bolt threaded full length, cut off the head to the proper length, dress the burrs with a file, and install your new stud with red Loctite ... after cleaning and degreasing the stud and hole.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-27-2003, 05:53 AM
smarjoram's Avatar
I may do that. How do I clean and degrease the hole? - I don't really want to remove the chain covers. Some sort of cotton buds? What solution? Thanks.
'81 SC
stefanmarjoram.com
sketch blog
flickr
Old 05-27-2003, 05:57 AM
Spray some Brake Kleen in the hole and let it dry or blow it out with compressed air.
-Chris
Old 05-27-2003, 06:01 AM
smarjoram's Avatar
Isn't there a danger of it spraying over the chain tensioners or doesn't it matter too much?
'81 SC
stefanmarjoram.com
sketch blog
flickr
Old 05-27-2003, 06:02 AM
Porsche Crest
You could just flood the hole with a solvent like Brakleen using the provided red plastic tube. After several shots, then allowing a few minutes to dry ... the hole should be clean.
Warren Hall, Jr.
Old 05-27-2003, 06:04 AM
