87 911 Trim Part Number
I am having trouble figuring out which part to purchase to replace the rubber door seal. It is worn from getting in and out on both sides and I would like to replace it. See below for what I am referencing.
Old 07-24-2022, 03:30 PM
Send a message via AIM to fintstone
Appears to be the door seal. Depends on if it is a Targa/cab or coupe.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-24-2022, 07:52 PM
If it is indeed the door seal, it should probably be
91153109503 for a coupe
91153109541 for a targa
Old 07-24-2022, 08:04 PM
Senior Member
Agree with above - door seal. I installed OEM recently, really easy. You will be closing the door a little more forcefully for a bit, but these are the last seals I will need.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 07-25-2022, 07:45 AM
Thanks! It’s a targa, appreciate it!
Old 07-25-2022, 08:16 AM
Senior Member
I just bought two coupe seals and trimmed them to tie into my targa seals. Gave me a lot of left over should I ever get any damage.
Chris
Old 07-25-2022, 11:29 AM
