Ubi bene ibi patria
Need Another Suggestion
Hi Again - How does one get these springs sufficiently compressed to complete their installation?
![]() I've tried You-tuber "Mikes Restorations" method using an old modified speed-borer without success. There has to be a simple way - short of taking the assembly to a machine shop. Thanks again for any suggestions. Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
Force the spring into an arc within the housing and start a punch in one side and the pin in the other, push the spring straight and tap the pin through.
Ubi bene ibi patria
Your solution was elegant in its simplicity - much appreciated - Thank you John
