Designer King
Paulporsche's Avatar
AC Compressor Belt Deflection
I have new Griffith's AC components on my car, including the Kuehl compressor.
Bentley's specs a 5mm deflection for the alternator belt for SC engines but I haven't been able to find a spec anywhere for the compressor belt.
Is 5mm reasonable deflection for the AC belt?
Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-19-2022, 07:27 AM
wrxnofx's Avatar
I honestly don't think it's that important of a spec. Make it loose enough that the belt doesn't slip on the pulley when the clutch is engaged. I just push on the middle part of the belt with my finger and if it deflects a certain amount I'm fine with it.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 07-19-2022, 04:06 PM
Yes just make it reasonably tight. Watch your horizontal deflection as well - lining up the pulleys is important.
Old 07-19-2022, 10:44 PM
Yea, it is hard to define, "tight enough" but not too tight.
It does not need to be cranked tight, and cause bearing wear. Just tight enough to not let the belt slip.
Old 07-20-2022, 07:49 AM
