Bosche Distributor 0231169008
Can someone look up this Bosche Distributor Number and let me know what its application was?
0231169008
Robert Currently Porsche less (but the wife has 2) |
it's a 1973 2,4 911 T dizzy.
Hessel
1971 911 2.2T |
Thanks, any difference between the 73.5 CIS and non CIS Distributors?
Thanks Bill
Here are the specs, I pirated them from someone here, can't remember who.
The same Bosch 2.4 911T distributor was used on MFI and CIS engines, and continued to be used on 2.7 CIS engines ... all with the 6500 rpm rev-limiting rotor.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Oops, now I'm worried, I was hoping to use this as a replacement for a Marelli on a 2.2, but did the shaft size change for the 2.4 motors?
The bore in the crankcase is smaller on the 2.0 and 2.2 engines, but a machine shop can turn down the distributor shank to fit the smaller bore. It has been done by other Pelicans successfully.
The adjustment 'ear' or tab on the 2.4 distributor needs to be cut off, too ... so the steel adjustment clamp for the 2.2 distributor can be used.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 08-05-2005 at 07:46 PM.. |
Thanks Warren, I thought it was larger.
Related to this discussion --
I also have a 1973.5 T with the 0231169008 distributor This of course uses the "Backwards points" as some people call it. Question --- does anybody have a link and/or part number for the correct "reversed" points used in this distributor ? I have ordered 4 sets now that were supposed to be correct --- but I keep receiving "standard" points Thanks |
Bosch 0 231 169 008 73.5 distributor uses either 901 602 960 00 ( Pelican listed for '72 MY) or 901 602 960 04 points.
911 602 936 00 points are for 1974-77 type 0 231 184 xxx distributors.
Ed 1973.5 T |
Thanks E Sully
