Which stapler will work
I am going to staple inside door panel to the "wood" door card. Which stapler is suitable to do the job...of course don't want staples to come through and don't want to spend a fortune on a stapler.
great thanks
I used a Porter-Cable 5/8” (the width of the staple top) Upholstery Stapler Model #US58, it’s the pneumatic model. Costs about $100 but I’m sure there’s cheaper ones available including some hand operated ones, which these are only good if you can get good steady pressure on a firm table/surface.
Make sure and measure thickness of both backer and material and use the proper sized staple, they come in varied lengths.
$19 is likely as econo wood puncher as it gets. And this takes a range of staple lengths.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
bought this one
hope it works! worry about staples coming through the door vinyl.
staple size?
Diss Member
The problem is that 1/4" staples are too long. You really need 5mm or 3/16" staples and those hard really hard to come buy.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Heck, I’m only 5 not 71!
The leather was one whole piece. It does not require glue to install, only staples on the backside edges where the leather wraps around. I used 1/4 “ staples and they came though the other side of the backer board. The original staples are a hair less than 1/4” and the replacement staples are 1/4” but the new padding covers the protruding staples tips and are not an issue with the leather. The thread on replacing door backer board is below.
https://forums.pelicanparts.com/porsche-911-technical-forum/1025491-replacing-door-panel-backer-board-cheap.html?highlight=Door
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
looks good!
you did a nice job...got the same thing going on..and more. Decided to paint the doors while they are stripped, along with the mirrors and power coated the handles.
