-   -   Help w/ which 964 windshield (there are 4 PNs) to install into a late G body? (http://forums.pelicanparts.com/porsche-911-technical-forum/1123788-help-w-964-windshield-there-4-pns-install-into-late-g-body.html)
famoroso 08-01-2022 06:37 AM
Greetings all,
I am planning to retrofit a factory 964 windshield and a factory 964 windshield seal to both my 1987 and 1989 911s.
Unfortunately, per the attached Technical Bulletin, my 1989 missed coming with the 964 windshield (and seal) originally by ~75 VINs...
http://forums.pelicanparts.com/uploa...1659363194.jpg
There are four different 964 windshield part numbers...
http://forums.pelicanparts.com/uploa...1659363239.jpg
964 541 011 00
Windscreen Tinted
964 541 011 09
Windscreen Tinted
964 541 011 01
Windscreen Tinted, Green Top Tint
964 541 011 10
Apart from the last two having green top tint, does anyone know the differences between the four part numbers?
I will be using factory rubber seal:
964 541 225 00.
Next question, does anyone know if the rear view mirror mount / plinth is the same, or if I'll need a 964 rear view mirror too?
Final question (for now) does anyone have recommendations for local shops in SoCal or SF Bay Area that have successfully installed the 964 windshield retrofit into a G body? My interior / upholstery guy in San Diego has done it and I will go with him for the installs, but I'd like to have a list of any shops with salient experience handy for reference purposes.
There are a few threads here regarding 964 windshield retrofits, but nothing definitive. Some say it works, others have had issues, etc. I'll report back after my own installs and, hopefully, this thread can be used as a more definitive reference, including part numbers, etc.
The patients...
http://forums.pelicanparts.com/uploa...1659364249.jpg
http://forums.pelicanparts.com/uploa...1659363818.jpg
rswannabe 08-01-2022 10:53 AM
The rearview mirror "puck" that the mirror body mounts to is just glued onto the windshield. New windshields do not come with them mounted. You can just reuse your old one and glue it onto the new windshield. The installer should do this for you
famoroso 08-02-2022 12:48 AM
Good news. Thx!
Ian Comerford 08-02-2022 02:02 AM
I have a 964 screen and seal in my SC and I would recommend looking for the aerial booster that plugs into the screen to enable you to take advantage of the built in aerial. You can then delete the wing mounted one
famoroso 08-02-2022 03:25 AM
Thank you Ian. Both my '87 and '89 already incorporate the in-screen antenna + booster.
Also, neither of my cars have a radio.
Joesmallwood 03-23-2025 02:38 PM
Checking in. How did this turn out? What windshield/seal part numbers were used and did they fit? I have an '81 SC with a cracked windshield so I am exploring going this route. Any info/help would be appreciated.
famoroso 03-26-2025 08:39 AM
Well, I acquired a 964 windshield and 964 rear glass, pre-owned, from Autobahn Dismantling in El Cajon, CA (the one time recepient of used parts from Singer's builds), so, unfortunately, I don't know which part number I ended up with. Here are the markings...
http://forums.pelicanparts.com/uploa...1743006665.jpg
What I definitely can say is that I am LOVING the look of the 964 front & rear glass + seals, especially in conjunction with the 993 rear quarter window seals. So much cleaner / smoother than the old school classic trim setup...
http://forums.pelicanparts.com/uploa...1743006952.jpg
Joesmallwood 03-26-2025 08:50 AM
That.......looks awesome. Nice work. I wasn't tuned in on the quarter glass having a 993 seal option, either. I will check that out.
mark4ton 03-28-2025 06:30 AM
much better! it always bothered me how even with a factory seal, the corners get sucked in
axvel 03-28-2025 09:41 AM
nice, thanks was looking for this info for a long time
proporsche 03-28-2025 11:42 AM
Nice job and looks great i have the same front in my 911-white 911 is my 2nd best color;-)
http://forums.pelicanparts.com/uploa...1743190632.jpg
http://forums.pelicanparts.com/uploa...1743190661.jpg
trials935 03-28-2025 03:38 PM
Does anyone know if the 964 windshield seal can be used with a stock 1988 911 windshield? Object is to eliminate the shrinking plastic trim pieces. What about the rear 964 seal, can it be used with a stock 911 rear glass also?
Terrafirma 04-04-2025 07:13 PM
No. From what I have read you have to use 964 rubber with 964 glass. I believe the glass is different sizes.
