DIY 3D Printing Tools and Parts Thread
Hello Pelicans, many of us have 3D printers as they have become cheap to buy and easy to operate. I would like to start this thread for folks to share their designs, ideas and files for others to use. It will save everybody time and therefore money.
I hope to get some participants. Greetings, Daniel |
I have been looking at cheap 3D printers and I wondered if I bought one where would I find the 3D build files. There are several vents that have been made by Pelicans for the CR Electrocooler AC system. Maybe they will post their files to this thread and all the files would be accessible in one place.
Let me load the ones I have to thingiverse this week. I am trying to get the slicing correct for the PETG as my first set of PLA vents warped when using my heat last winter.
Pat - I still owe you a set. I'm actually printing them now. |
I have a bunch that I can load into thingverse.
Last winter I floated the idea of building a Porsche 3d printed file repository but it was received with crickets... |
Hey Showdown, glad we share the same thought. We can use this Thread to have discussions on new printed components, also requests that some members maybe have but use thingverse for holding the files?
Daniel |
Ha! The Porsche wall letters are mine! I have a few more interesting designs.
Very keen on a repository for 911 files. I'm pretty new to 3D printing, but made this up last week for my 911, its mounted to the original center console mounting holes on my tunnel with 2 screws (107mm c2c) I'm not sure if this is universal on all models or someone had drilled mine previously for the console. It may or may not be of use to others?
https://i.ibb.co/Nt3bNrd/Capture.jpg https://i.ibb.co/ys2GT2t/20220730-180840-edit.jpg |
That's dope. Subscribed.
Thanks |
How about some door striker parts? I’m thinking about buying a 3D printer what would you guys recommend for making car parts?? Et. I’m not into Marvel action figures.
Dash pull knob buttons for repurposing to control AC or an oil cooler fan:
https://www.thingiverse.com/thing:5447649 Classic Retrofit AC parts: https://www.thingiverse.com/thing:5447651 Hand throttle collar stop for throttle rod (NLA): https://www.thingiverse.com/thing:5447656 |
Here are my Door Buffers - I've got about 10K on them and they are still fully functional. These are 100% original design, model, test by me. https://images.squarespace-cdn.com/c...EG?format=500w https://images.squarespace-cdn.com/c...EG?format=500w https://images.squarespace-cdn.com/c...EG?format=500w https://images.squarespace-cdn.com/c...pg?format=500w https://images.squarespace-cdn.com/c...EG?format=500w Love this group!!! More to come. jmd |
I made this equalizer box for my period correct blaupunkt system. I also incorporated a couple of USB ports at the back to power the phone.
https://i.imgur.com/uRUbq0B.jpg It’s a no-drill install that gets it under the dash and gives a tidy phone input for the rennline phone mount. The equalizer used to be on the console but I wanted to mount a center AC vent, hence the box. https://i.imgur.com/dHuhz0x.jpg The phone wire routes through the ashtray, so it can be tucked away when not in use. There’s a second charger wire in the ashtray for passengers. The entire system uses Bluetooth (hidden behind equalizer box) to transmit through FM. It works great except for the hiss of static before the Bluetooth cuts in. Figuring out how to maybe time delay the amp on power up to fix that, or something similar. |
@jmd88 - thanks for this! I was just looking up acquiring new ones since they are crumbling on my coupe. It doesn't look like you can buy them separate. Firing up the printer now. Can you check the link to your files? I'm getting a 404 on thingiverse.
Which printer should I buy???
I'm running a Creality CR10-Mini and it seems to be working fine. I need to convert my prints from PLA to PETG, but so far with PLA it has been really good. I think I paid around $200.
I just created my thingiverse account so it might still be propagating.
Does this work: Link to .STL if not, DM email and I'll send it over. Quote:
Hope that helps. |
| All times are GMT -8. The time now is 08:17 PM. |
