-   -   Part ID needed (http://forums.pelicanparts.com/porsche-911-technical-forum/1123853-part-id-needed.html)
jgurnari 08-02-2022 06:13 AM
Part ID needed
do you recognize this part?...believe it came from inside the door. "85 911http://forums.pelicanparts.com/uploa...1659445968.jpg
Flat6pac 08-02-2022 06:18 AM
Part of the roll up mechanism inside door
Bruce
jgurnari 08-02-2022 06:29 AM
fell off I guess....this a problem? window seems to have been working fine
chrisbalich 08-02-2022 06:37 AM
It's the anchor for the large spring in the window lift. Your windows will still go up and down, but will require more effort to raise than with a functioning spring.
**Assuming it's not a leftover from a previously failed lift.
chrisbalich 08-02-2022 06:39 AM
http://forums.pelicanparts.com/uploa...1659447539.JPG
The anchor is the same for parallel arm regs as well as the more modern regs.
jgurnari 08-02-2022 06:48 AM
Will I be able to simply push it back in place?
Hoping to find that it was replaced at some point...replacing the one I found.
chrisbalich 08-02-2022 07:00 AM
You may be able to push it back into place. But it will need to be welded from the rear in order for it to function correctly.
jgurnari 08-02-2022 12:00 PM
sounds like a nightmare job! window removed and all that? …now i’m praying that there is one is in place.
chrisbalich 08-02-2022 12:58 PM
Nah, takes more time to get the regulator out and in than anything else. The welding only takes a moment. All-in, one of the easier fixes.
Classic 08-02-2022 01:03 PM
Fit a new one from our host, held in place by a screw rather than peened over….Just use a little lock tight.
jgurnari 08-02-2022 04:31 PM
i can just put in a screw? need to buy a new one and screw it in?
HarryD 08-03-2022 12:21 PM
The hard part is getting the regulator out and back in. Replacing the part with the correct piece only takes a few moments.
Part comes in 4 flavors. order the correct one. Find it here: https://www.pelicanparts.com/byb-rennline/c-body-seals_c-bumpers-doors-latches-lids_c-weltmeister-window-regulator-pivots
How to remove regulator: https://www.pelicanparts.com/techarticles/bob_tindel/911_window_regulator.htm
jgurnari 08-03-2022 01:26 PM
will my old one work? or do i need to purchase a new one? something missing or broken from it that it won’t work again?
http://forums.pelicanparts.com/uploa...1659558381.jpg
HarryD 08-03-2022 02:07 PM
It might but then again it may fail again due to becoming misshaped. Buy the new part. Once and done.
HarryD 08-03-2022 02:10 PM
New part. Note relative size end without the slot.
http://forums.pelicanparts.com/uploa...1659560992.png
917_Langheck 08-03-2022 03:27 PM
Since the old one already has a hole in it, why not use a low profile tapping screw - or tap with an appropriate size and pitch and use a machine screw - with a washer like the new one linked earlier in this thread?
HarryD 08-03-2022 03:29 PM
You can but the original part is pot metal which is why it failed in the first place.
Do it right, do it once.
917_Langheck 08-03-2022 03:33 PM
Did it fail, or did it loosen and fall out? Pot metal, and someone suggested welding it, uh, no....that is why I suggested the machine screw. It's just a suggestion.
jgurnari 08-03-2022 05:58 PM
will i be able to get a screw in without removing the window lift?
is it facing the door opening or the opposite side.
917_langheck, i just found it off in the inside of my door, not sure if it broke or just fell off. have to look.
HarryD 08-03-2022 07:06 PM
You will need to remove the regulator. Not hard.
