-   -   In the middle of first engine drop on 87 - not sure where I disconnect the G50 slave (http://forums.pelicanparts.com/porsche-911-technical-forum/1124081-middle-first-engine-drop-87-not-sure-where-i-disconnect-g50-slave.html)
BrakeL8 08-06-2022 11:58 AM
Would love some beginner help if possible. Do I disconnect the hydraulic line from the car where it goes into the slave just next to the bleed screw? Or do I somehow unbolt the entire slave cylinder?
Attempting to drop 3.2 motor and g50 transmission at the same time.
Thank you!
BrakeL8 08-06-2022 12:23 PM
Bentley to the rescue. Got it
john walker's workshop 08-06-2022 06:57 PM
Yeah, two nuts off and set it aside. Do it after you lower the engine a bit and lean over the top. assemble the same way. Tie the clutch pedal to the steering wheel.
